Evening!
Discussion in 'New Member Introductions' started by Hobbywelder, Nov 27, 2021.
  1. Nov 27, 2021 at 6:49 PM
    Hobbywelder
    Hobbywelder [OP] New Member
    Dustin
    ‘93 F-250 XLT
    Evening all!
    Short time reader of the 1st gen forum, looking to pick one up.
    its time to temporarily retire my sweetheart, a 1993 F-250 XLT with the 351 windsor, ZF 5 speed manual, borg warner T-case and 4.10’s. At a 180k miles, she’s showing her age. Motor needs to come out for a rebuild, and ford definitely didn’t make it as easy as it should have been.
    So, about me. Im a Body tech (collision repair) and I also do diagnostics, and upholstery. Those two aren’t as common nowadays for us, we have a separate group that does most of that for us. Strange times…
    6 year army vet, keepin’ on keepin’ on. Maybe ill hit 20, maybe 8-12 will be enough for me.
    Avid hunter and fisherman, I also volunteer to get vets and leo’s out so im gone almost every weekend.
    Ill be over in the 1st gen forum asking a boatload of questions, I may know the body side but mechanical not so much.
  2. Nov 27, 2021 at 7:09 PM
    WhyW8
    WhyW8 “It’s ALWAYS Loaded”
    HB
    Sunny AZ
    2017 Super White SR5 CM
    Level Kit, DiamonBack Tonneau, Step Boards, Alpine Amp, Cerwin Vega powered Sub
    Welcome from AZ
    Hobbywelder[OP] likes this.
  3. Nov 27, 2021 at 7:17 PM
    Hobbywelder
    Dustin
    ‘93 F-250 XLT
    To explain my current truck’s situation. Long winded fyi: ‘93 F250 XLT, 4.10’s, 4x4, ZF-5 manual with the 351 windsor. Factory rated 200hp and 300lbft. I bought it from the original owners, my parents actually. I knew exactly what had been done and how it was treated.
    Getting close on the 181k mark, and she’s getting tired. Main bearings are showing wear, trans syncro’s are showing it, etc etc. Now, she LOVES to pull and it does so well. Being nearly 6800lbs, and 23ft long (Supercab long bed, with a ranch hand) I have yet to find a trailer that dares to sway or feel unsteady. But, its slow. On passes: 45mph loaded or unloaded, 3rd gear and 3500rpms, unless its a low speed limit or pushing its max weight and then some. 65mph highway (75 speed limit) turning 3k rpms. I could run 75 but thats not the greatest for trailer tires.
    anyway, now I have an oil pan leak, which requires picking the motor up a good 3+ inches to re-seal. And a coolant leak I haven’t found yet. Its somewhere off the passenger bank, I have dye that’s going in soon. I pray its just a line or a freeze plug as the truck has never seen anything over 210 water temp. But at 181k there’s a very slim chance a head gasket is leaking externally.
    beyond that, im gone hunting and fishing so much, I don’t have the time to get the truck down. Plus, I would like to swap axles, build motor, build trans, add GV overdrive, repaint, redo the interior, etc etc.
  4. Nov 27, 2021 at 7:18 PM
    Blueknights75
    Ron
    Clayton, NC
    Welcome from NC!
  5. Nov 27, 2021 at 7:21 PM
    Hobbywelder
    Dustin
    ‘93 F-250 XLT
    Thanks folks!
  6. Nov 27, 2021 at 7:49 PM
    Welcome from NY.
  7. Nov 27, 2021 at 8:09 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Welcome from SoCal. Best Gens are cool.
  8. Nov 27, 2021 at 8:15 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  9. Nov 28, 2021 at 5:35 AM
    2mchfun
    Welcome from OKC!
  10. Dec 5, 2021 at 6:06 PM
  11. Dec 5, 2021 at 7:34 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada
  12. Dec 5, 2021 at 8:35 PM
    Rgross2112
    Rush
    2020 Silver TRD Limited
    Avid hunter, fisherman and veteran as well. Thank you for your service and welcome to the forum, from Pennsylvania
  13. Dec 6, 2021 at 6:03 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Star, Idaho
    TRD Lowered and Supercharged
    welcome from so cal
