Error codes - won’t start
Discussion in '2nd Gen Tundras (2007-2013)' started by sbtgrfan, Jun 3, 2020.
  1. Jun 3, 2020 at 5:18 PM
    sbtgrfan
    sbtgrfan [OP] New Member
    Stephen
    Chattanooga, TN
    2023 SR5 TRD Sport 4x4 CrewMax Midnight Black Metallic
    Hey y’all,
    My 2008 5.7 Tundra won’t crank & start (I get nothing at all). Battery is good, and I just had the alternator replaced within the past year or so. I’m getting error cods p0335 p0340 p0345 p0365 p0390. Truck will jump start right away and run fine but as soon as I turn it off it won’t start back up unless jumped.
    Any ideas what I can do before I take it to the shop?
    Thanks,
    Stephen
    Mnorris1206 likes this.
  2. Jun 3, 2020 at 5:42 PM
    Mnorris1206
    08 tundra
    Crazy but could it be another bad altinator?
  3. Jun 3, 2020 at 6:47 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Check your grounds, check fuses... may seem like an electrical fault may be the issue... May be a starter issue... or may be an ECM issue, but someone with more electrical knowledge may be of help... Starter is a bitch though...
  4. Jun 3, 2020 at 7:40 PM
    MS22
    MS22 New Member
    02 Tundra 4x4
    Did you test the battery with a multimeter?
    Filthyphil likes this.
  5. Jun 3, 2020 at 10:27 PM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    Test to see what your new alternator is putting out.
  6. Jun 3, 2020 at 10:52 PM
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    12volt remote start, weathertec accessories, Trd Pro decals, Toyota console safe,VLEDS Puddle Lights,Frac Harness,TRD PRO front and Rear Sway Bar,NSV Hood Light Bar,ESP long box,AJT accessories,Thinkware U1000 dashcam, coachbuilder 1/3 Lift, HR LED’s,Pro comp Traction bars, JL complete System wit 2 10” subs, Kenwood DDX9907XR HU
    I’m sorry but all signs point to a bad battery if it starts and runs fine with a jump start I would put a fresh battery in it and test the alternator for charging even if you don’t want to buy one Then test it with a friends battery just make sure it’s a top post doesn’t matter how many CCA it’s just for testing purposes and if it starts up and runs fine then buy a new battery and don’t forget that Toyota’s need to relearn wen you have a dead battery so make sure all accessories are off and let the truck idle for a good 10-15 min so it can relearn
  7. Jun 4, 2020 at 4:22 AM
    sbtgrfan
    Stephen
    Chattanooga, TN
    I did test battery. 12.6v with engine off, 13.6v while running.
    Definitely seems to be a connection/wiring/electrical issue. Driving to work this morning all the gauges and the screen cut out on me randomly a couple times (though truck continued to drive fine) and the lights were blinking a little as was the clock and some other things. I've cleaned the battery terminals well and the connection there is tight. Might just have to give in and take it to a shop to check things out.
  8. Jun 4, 2020 at 12:19 PM
    Filthyphil
    Phil
    Lights cutting out is low voltage, 13.6 is garbage for a fairly new alternator, I would put a full load on it and see what it does. Take your alternator off and get it tested at least and your battery. If it jump starts fine but won’t start on it’s own that’s not a truck electrical problem that’s a initial voltage problem. The next time it won’t start on its own check what the voltage is before you jump it.
  9. Jun 4, 2020 at 1:38 PM
    blackdemon_tt
    You don't have to remove the alternator to get it tested, take it to an Oreilly, pep boys, or a service station to get the alternator tested, I don't think autozone does it, but I may be wrong. It may sound like a battery problem, I've stalled out while the truck is running and the alternator is fine, so far 220k and still going, batteries are a different story... My SC400 just killed a 3 month old battery, took it in to get tested and its not holding a charge, so I've swapped it out...
  10. Jun 4, 2020 at 1:50 PM
    sbtgrfan
    Stephen
    Chattanooga, TN
    I get a half mile from Autozone and the truck completely stalls out. Able to jump it and get to autozone. Battery was still under warranty so had it replaced and it started right up. Hopefully that’s all it was! $0 potential fix!
    Thanks for everyone’s advice!
  11. Jun 4, 2020 at 1:55 PM
    blackdemon_tt
    Hopefully that will be your answer, as summer goes full blast I expect a surge in stalling and batteries dying... I went through 9 batteries in 6 months at one point and time including 3 factory direct replacements, and 3 Optimas, 2 red and 1 yellow top...
