Erratic blower fan speeds. Help please
Discussion in '2nd Gen Tundras (2007-2013)' started by Jockey, Aug 17, 2025.
  1. Aug 17, 2025 at 4:58 PM
    Jockey
    Jockey [OP] New Member
    Albert
    2013 Toyota Tundra Crew Max 4x4
    2010 Tundra SR5 HVAC blower inconsistent speeds when on high. Replaced the blower fan assembly with an aftermarket and doing exact same thing. Where would I go from here? A relay? Or replace the dial on dash / switch? Thanks in advance.
  2. Aug 17, 2025 at 5:08 PM
    WhiteSR5
    WhiteSR5 New Member
    SC
    2021 DC SR5 4x4 (guess the color)
    Check the connector to the blower motor… make sure there is no corrosion and is fully seated.
    I would suspect the blower motor resistor, but I don’t think the 2nd gen has one, meaning speed is controlled by the HVAC amplifier (control unit). I would definitely want a good diagnosis before throwing parts at it.
    check out post#5 for diagnostics: https://www.tundras.com/threads/ac-amplifier-replacement.75065/
  3. Aug 18, 2025 at 12:21 PM
    Jockey
    Albert
    Thanks for the reply. I checked the connector. It appears to be free from corrosion. It looks like the resistor is built into the blower fan assembly itself. I guess I could buy a 3rd one to see if I possibly purchased a faulty new aftermarket. But it is doing the exact same thing as the OE blower fan. When I place it on the upper speeds or close to high, it will become erratic and change speeds.
  4. Aug 18, 2025 at 6:21 PM
    WhiteSR5
    WhiteSR5 New Member
    SC
  5. Aug 18, 2025 at 6:27 PM
    2mchfun
    Feed the old one juice directly from the battery with jumpers, probably nothing wrong with the motor. Which means wiring, switch, control unit, etc.
  6. Aug 18, 2025 at 6:29 PM
    2mchfun
  7. Aug 19, 2025 at 8:05 AM
    Jockey
    Albert
    When I wiggle the switch on the dash, I feel like I can sometimes get the fan to change speeds. That gives me the indication that it might be in the fan speed switch. Looks like might have to buy the entire control unit to get that switch. Am I seeing that correctly?
  8. Aug 19, 2025 at 9:29 AM
    WhiteSR5
    WhiteSR5 New Member
    SC
    How good are you with a multi meter?
    Do you have automatic climate control (where you set temp) or just cold-hot variable knob?
    Like 2mchfun suggested, bench test the blower motor by feeding with direct battery power (with engine running). Bonus points if you can get a current (amperage) reading; it should be consistent while running.
    2mchfun likes this.
  9. Aug 21, 2025 at 4:35 AM
    Jockey
    Albert
    My fan speed switch is manual switch vs the automatic climate control. Unfortunately I do not have a multimeter, but I could buy one .
