"Equal" internal tire balancing?
Discussion in 'Wheels & Tires' started by MotoTundra, Dec 26, 2017.
  1. Dec 26, 2017 at 5:43 AM
    MotoTundra
    MotoTundra [OP] The Ocho
    Don
    So today I ordered a set of BFGoodrich All Terrain KO2's and the shop recommended they use "Equal" powder to balance them instead of wheel weights. I went with OEM size, 275/65/R18.
    They also have road force, which is what I requested at first.
    I am thinking of sticking with the Road Force, but wanted to see if you guys have had any experience with Equal.
    Thanks!
  2. Dec 26, 2017 at 5:58 AM
    muisejt
    muisejt New Member
    2017 Sunset Bronze 1794 Edition 4x4
    Auburn LSD, TRD rear sway bar, LED interior lights, Weathertech floormats, Fumoto valve
    Sounds like bead balancing. I have my winter tires done that way. My buddy is a mechanic and has done all his personal vehicle that way for years. Only issue my buddy has mention is if the vehicle sits for a while the beads will stick together and you'll get a square tire feel for a couple miles when you first take of.
    MotoTundra[OP] likes this.
  3. Dec 26, 2017 at 6:04 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I had never heard of this and went on line to learn about it. I also spot checked several different forums and read discussions and reviews.
    I suggest that you do the same.
    What I learned is enough to never use the stuff. Moisture can make it clump up and it can get into the valve and cause slow leaks, apparently.
    It’s also not as effective on wider tires.
    If you choose to use it, please post back after a few months to let us know what the results are.
  4. Dec 26, 2017 at 6:11 AM
    MotoTundra
    Don
    One thing I know is there is nothing wrong with road force....
    theboy12 and AxelsHumanDad like this.
  5. Dec 26, 2017 at 6:17 AM
    My car's I always road force balance. My 35's on the Tundra it wasn't an option.
    14burrito and MotoTundra[OP] like this.
  6. Dec 26, 2017 at 6:22 AM
    Slayer
    Slayer Member
    Slayer
    a buddy used beads on his motorcycle wheels .. he swore by them
    one day we were out for a long ride..
    a bead got stuck in the valve stem when he checked air pressure.. & got a slow leak.
    luckily I keep a small compressor in my saddlebag.. had to stop every 30 minutes or so till we got to a town with an open tire store.
    new valve stem please
  7. Dec 26, 2017 at 6:59 AM
    I used to get the road force but didn't seem to make much difference. Can't hurt. I'd stay away from the "Equal". Road force really helps out a lot with low profile tire, tall rim setups that can pick up extraneous vibrations and amplify them. Well made high profile tires seem to be somewhat immune due to the the taller sidewalls. IMHO.
  8. Dec 26, 2017 at 7:22 AM
    MotoTundra
    Don
    Good info, much appreciated!
    Black Wolf likes this.
  9. Dec 26, 2017 at 7:34 AM
    AxelsHumanDad
    AxelsHumanDad Get off my lawn.
    KAIG, NW of The Frozen Tundra
    2015 CM Platinum
    Some suspension tweaks
    Stick with the road force. :thumbsup:
    Black Wolf and MotoTundra[OP] like this.
  10. Dec 26, 2017 at 11:20 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Wait, what?
    MotoTundra[OP], Slayer and Black Wolf like this.
  11. Dec 26, 2017 at 11:40 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Exactly that, a shop tried it on my Jeep. It worked 'ok' for about 6 months then was worse than ever. Then they were mad they had to clean all of the crap out.
  12. Dec 26, 2017 at 2:27 PM
    MotoTundra
    Don
    For multiple reasons, my decision is made.
    Road Force it is.
    Thanks for all the input guys!
    Prostar 190, gosolo and Black Wolf like this.
  13. Dec 26, 2017 at 3:38 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Road force with weights
