Environmental splices
Discussion in 'Electrical' started by Tundra234, Nov 30, 2021.
  1. Nov 30, 2021 at 6:14 PM
    Tundra234 [OP] New Member
    What do you guys have for environmental splice kits? I want to clean up some wiring and environmental splices would be better that heatshrink. Thanks.
  2. Dec 1, 2021 at 2:20 PM
    ezdog
    ezdog New Member
    Gateway To The West
    What exactly is an Environmental Splice Kit?
  3. Dec 1, 2021 at 2:34 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    I believe he is referencing the butt connections that have the solder and heat shrink built into one. They make for easy and clean wire connections.
  4. Dec 1, 2021 at 2:36 PM
    ezdog
    ezdog New Member
    Gateway To The West
    How are these considered to be or not to be "Environmental" though?
  5. Dec 1, 2021 at 2:37 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    I had to look them up. What's wrong with solder and 3:1 shrink tubing with adhesive liner?
    2mchfun likes this.
  6. Dec 1, 2021 at 2:59 PM
    ezdog
    ezdog New Member
    Gateway To The West
    OK so these are just a butt splice covered with heat shrink with adhesive inside nothing more and nothing less so I guess now I really do not understand the question?
    FrenchToasty likes this.
  7. Dec 1, 2021 at 4:02 PM
    Correct...exactly what I am looking for.
  8. Dec 1, 2021 at 4:06 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    A lot of people boo and hiss at soldering in the automotive world, they say it can get brittle and from vibration break the solder joint and other failures…………. Sounds to be like they can’t solder…….
  9. Dec 1, 2021 at 4:08 PM
    alb1k
    Left Coast
    It's good
    Agreed, a cold solder could do that. A good solder on the other hand with cable management - good luck breaking that.
  10. Dec 1, 2021 at 4:09 PM
    FrenchToasty
    Mo
    Bone stock
    I pre-tin everything and watch it flow
    2mchfun and alb1k[QUOTED] like this.
  11. Dec 1, 2021 at 4:22 PM
    ezdog
    ezdog New Member
    Gateway To The West
    There isnt really any downside either though to properly made butt connections it is just that most do not get the correct tool for the butts that they use that can give them a bad name.
    I would always choose separate splice and shrink though no reason to crimp heat shrink that is good at all?
  12. Dec 2, 2021 at 11:02 AM
    TravisJr
    TravisJr New Member
    2001 AC SR5 4WD, 2010 DC SR5 4WD
    Lots o’ mods
    alb1k likes this.
  13. Dec 2, 2021 at 11:33 AM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    I use these a lot for connections in my car and especially in my boat. Water getting into a splice or any wiring for that matter is BAD NEWS. You could develop gremlins that you'll never get rid of. If I dont have environmental splices I'll use regular butt splices but wrap them in electrical tape and then coat them with liquid electrical tape; basically making them environmental.
  14. Dec 2, 2021 at 3:34 PM
    jrquist
    jrquist Canon Shooter
    Carlton, Minnesota
    2020 Tundra Sport Super Bright White
    This is what we use almost everyday at work. Not this exact brand but something similar. They work great and when shrunk they have a lot of holding power. If you have to redo you only lose about 1/2" of wire. We are butt splicing most 12 and 14 and 18 gauge wire. Most of it is exposed to the outside elements.
    https://www.amazon.com/TICONN-Conne...+with+heat+shrink&qid=1638487760&sr=8-1-spons
