ENGINE - TRAC OFF - 4LO warnings
Discussion in '2nd Gen Tundras (2007-2013)' started by swashplate, May 24, 2020.
  1. May 24, 2020 at 7:38 AM
    swashplate
    swashplate [OP] New Member
    Robert
    2012, White, dbl cab, SR5, 4X4
    Nerf bars, Grill emblem
    Hello everyone. Yesterday I took a short round trip of about 350 miles. No issues what so ever. Today my wife and I decided to go do some shopping. I slowed at a corner to make a turn and when I went to speed up the Tundra was acting sluggish. Looked at the dash and saw the warnings, "ENGINE" and "TRAC OFF" indicators constantly on. Also the 4LO indicator was blinking. I had not put it into 4WD in the last 2 days. I used the 4WD system about 3 days ago in some torrential down pours.
    The truck seemed to perform normally except that, when I really got down on the accelerator, the RPM's would rise but the vehicle would not speed up - like it was in 4 wheel low. If i drove it normally, it would go through the gears as it should and get up to speed. 50 MPH was the fastest I got it up to this morning.
    This Tundra is a 2012 Double Cab, 4.6L, SR5, TRD, 4 wheel drive. No mods other than step tubes and grill emblem.
    Any ideas? Thanks.
    Robert
  2. May 24, 2020 at 9:50 AM
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    Sounds like an AIP failure. Search this site you’ll find tons of info on it. There’s luckily a bypass kit you can buy. You mentioned “torrential downpour”, that’ll start making sense when you dive into the AIP system.
