Engine swap
Discussion in '1st Gen Tundras (2000-2006)' started by jv384, Feb 9, 2025.
  1. Feb 9, 2025 at 6:24 PM
    jv384
    jv384 [OP] New Member
    2002 Regular Cab
    Bilstien shocks all around, wheels & tires
    Hey everyone. The topic of engine swapping my 3.4 Tundra has been crossing my mind a lot lately. I want to have some power and the stock 5vz is just very limited even with a supercharger. I've been thinking about a 2jz ge or gte, 1uz, or a 4.8/5.3 ls. I like the sound of the Toyota motors because I may be able to reuse my a340 and prob not have to mess with the driveshaft. I know the distributor setup on the 1uz makes it a little more complicated, although I have found a high mileage one for 800 (full car) from a friend. But I do know the 4.8/5.3 you cannot go wrong with. For simplicity, I would use a standalone ECU (Holley EFI or Haltech). Any input? What is my cheapest option for solid power for light towing & speed? Which option is the simplest and easiest to drop in? Thanks
  2. Feb 10, 2025 at 6:41 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    It's gonna be a lot more work than you think.
    efficient way. Sell it. Get truck w/ v8
    I doubt the tranny would be able to be utilized. Just cause they probably don't make an adapter plate for it.
    Which then leads to a custom driveshaft or finding one that fits ect.
    Not saying you can't do it. It's been done. It's just not as simple as plug and play. Ever.
  3. Feb 10, 2025 at 6:14 PM
    Dustbox
    Dustbox New Member
    Southern Utah
    2000 Black AC 4.7l V8 4x4 SR5
    285/75/r16 tires on stock suspension Tubed Bumpers
    From what I've heard the 5vz's internals are good as high as 450hp. Granted getting there is $$$.....
    That regular cab with would be a beast with some more ponies.
  4. Feb 10, 2025 at 6:18 PM
    Sirfive
    Sirfive Master Procrastinator
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
