Engine swap from 2008 to 2016, supercharger plumbing help needed
Discussion in '2.5 Gen Builds (2014-2021)' started by Dartinguphill, Jun 29, 2021.
  1. Jun 29, 2021 at 3:39 PM
    Dartinguphill
    Dartinguphill [OP] New Member
    TJ
    2008 Tundra Supercharged rebuild
    TRD Supercharger King Shocks Sh*tComp lift Brembo rotors, calipers, brakes Exhaust
    The 2016 engine has 2 small coolant hoses that come off the PCV valve and there are no barbs to hook into the coolant crossover manifold. What is the work around? do i need them or can i just cap them off?
    thanks for the help
    tj
  2. Jun 29, 2021 at 3:42 PM
    AZTundra
    Paul
    Phoenix, AZ
    Do you have a picture?
  3. Jun 30, 2021 at 7:48 PM
    Oats87
    Oats87 Dirt Rider
    Sunnyvale, CA
    A Non-Toyota
    I believe you are referring to the heated PCV valve that is on the 2014+ trucks.
    If you look at step 55 on page 18 of the installation manual here: https://www.magnusonsuperchargers.c...les/manuals/89-89-67-003_RevJ_Tundra_5.7L.pdf you'll be able to trace through the rest of the manual and see that it's connected to the throttle body and the thermostat. You can probably cap it off, but don't hold me to that. Kind of a PITA to get under a supercharger because they're so heavy.
  4. Jul 1, 2021 at 1:58 PM
    Dartinguphill
    TJ
    Thank you very much! that is correct.
    tj
