Engine swap 3.6 for 4.7
Discussion in '1st Gen Tundras (2000-2006)' started by Wnance, Jun 13, 2016.
  1. Jun 13, 2016 at 6:39 PM
    Wnance
    Wnance [OP] New Member
    2001 red tundra
    I have a 2001 tundra with 4.7 blown engine. Found wrecked 2002 tundra with 3.6 v6. Trying to install 3.6 into 2001 but motor mounts on frame don't match. Anybody know where I can get swap engine mounts to match 3.6 to 4.7?
  2. Jun 13, 2016 at 7:06 PM
    Mike Tread lightly.
    south carolina
    You talking about the 3.4 (5vz-fe)?
    jberry813 likes this.
  3. Jun 13, 2016 at 8:05 PM
    Wnance
    2001 red tundra
    Yeah 3.4 v6
  4. Jun 13, 2016 at 8:41 PM
    Mike Tread lightly.
    south carolina
    Toyota use different mounts than the 4.7 vs 3.4 if my memory is right.
    mounts can be had junk yard or dealer or parts store.
  5. Jun 14, 2016 at 6:44 AM
    Wnance
    2001 red tundra
    The mounts welded to the frame are different so I need some adapters to mate the V6 to the frame either the V8 mounts.
  6. Jun 14, 2016 at 7:57 AM
    Mike Tread lightly.
    south carolina
    Honestly you might have to fab something up to do it. Conversion in our trucks are rare anymore unless you go pre 1995.
    Why don't you save the headache and pita and just drop other 4.7 in.
    KarmaKannon likes this.
  7. Jun 14, 2016 at 8:57 AM
    Wnance
    2001 red tundra
    I think you may be right. I could cut the V8 mounts off and weld the V6 mounts in place, but I am leaning toward rebuilding the 4.7 or finding a used one. I think the trannys are the same for the 3.4 and 4.7 so hopefully I could use the 3.4 tranny I have now with only 150K miles on it.
  8. Jun 14, 2016 at 9:36 AM
    Mike Tread lightly.
    south carolina
    If the engine is out and on the stand I would rebuild the 4.7. long as the block is good. Off the heads to a machine shop for leak down test..
    What was the failure of the engine to begin with?
  9. Jun 14, 2016 at 10:05 AM
    Wnance
    2001 red tundra
    Timing belt broke. Since it is an interference engine I will have to pull the heads to see how much damage was done. Engine has 270K on it. Found a used 4.7 with 109K for $1100 so I may go with that.
  10. Jun 14, 2016 at 10:09 AM
    Mike Tread lightly.
    south carolina
    Ouch.. bend valves I bet but sometimes you get lucky at times I would check it.
    1100 is not bad I would rebuild the front end, seals, water pump and all timing components. That way you saved a headache down the line.
  11. Jun 14, 2016 at 11:51 AM
    Wnance
    2001 red tundra
    Good advice -- thanks for your help Mike.
  12. Jun 14, 2016 at 12:29 PM
    Mike Tread lightly.
    south carolina
    Glad I could help.
  13. Apr 14, 2021 at 11:02 AM
    Antonio_02
    Antonio_02 New Member
    I'm doing something similar but a cab sawp do I use the wiring in the dash from the v6 cab on the v8 cab note doing a manual conversion aswell so I'm kinda stuck on the wireing because the dash wiring from the cab that was a v8 model has more connections for the automatic like the ignition speedometer etc
    Unlike the wiring harness in the dash for the v6
  14. Apr 14, 2021 at 9:15 PM
    NWPirate
    Zach
    WA
    Welcome!
    You might have a hard time getting a response on a 5 y/o thread.
    @empty_lord or @Tundra2 might have a bit of advice if you ask super duper nice.:thumbsup:
  15. Apr 14, 2021 at 9:57 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    This is an interesting, and complex problem to my eyes. It's unfortunately, completely out of my wheelhouse. I am no help here.
    I'll definitely be following to learn though.
    NWPirate likes this.
  16. Apr 14, 2021 at 11:24 PM
    Antonio_02
    Ok so the 3.4L with the 5 speed 01 tundra was in a
    Rollover. So the donor cab is the same year cab but has had the 4.7L with the automatic tranny so thus I am doing a cab sawp and a manual conversion which includes cutting out mounting points for the clutch master cylinder and parking brake in the fire wall also cutting a section out the floor for the tranny and T-case shifters as well as swapping the steering column so the interior wiring harness was swapped around and because the 4.7 interior wiring harness didn't have the clutch cancel start wired and the speedometer has 5 connections while the 3.4 interior wiring harness has 4 to the speedometer so I was trying to figure out if I could use the 4.7 interior wiring harness but to be safe and from looking on 1st gen fourms I decided to use the 3.4 interior wiring harness in the donor cab
    Chuck4x4 and NWPirate like this.
  17. Mar 27, 2022 at 6:30 AM
    Chuck4x4
    Chuck4x4 New Member
    Kentucky
    2002 rebuilt tundra
    JDM engine swap, dog house swap
    Would you happen to have a few pictures of your cross member? I’m doing a 5 speed swap in my 3.4 and needing a few things to reference
