Engine swap 3.4l
Discussion in '1st Gen Tundras (2000-2006)' started by BDScott, Aug 22, 2022.
  1. Aug 22, 2022 at 7:33 AM
    BDScott
    BDScott [OP] New Member
    2002 tundra 3.4l 4x4
    Hello,
    I have a 2002 Tundra 3.4l 4x4 with a bad engine, I found a great running 3.4L engine from a 2002 4runner. Will this motor from the 4 runner have any issues in the tundra? Any things that make them different that I may need to know before doing the swap?
    Thanks for any help!
  2. Aug 23, 2022 at 9:27 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Didn’t you post this in a different thread? I’m having déjà vu.
    yes 4Runner will work. You’ll need to use all the tundra electronics though and ecu/harness
    des2mtn likes this.
  3. Aug 24, 2022 at 4:10 AM
    BDScott
    Yes I posted it twice...lol I was desperate. Thanks for your reply.
    If I get the ecu for the 4 runner and swap it into the tundra, could I leave the electronics on the 4 runner motor? I will take the easier route, just not sure what route that is.
  4. Aug 24, 2022 at 7:41 AM
    empty_lord
    05 rollover special
    4runner ecu will not play nice with the tundra. Nothing in the dash will work.
    Just swap the engine harness from the tundra to the 4runner engine. And whatever the tundra has that looks different swap over
    things like the cam and crank sensor, oil pressure sensor will be the same and safe to use
