Engine stumbling... especially under load
Discussion in '1st Gen Tundras (2000-2006)' started by Kollinowens, May 22, 2020.
  1. May 22, 2020 at 9:25 PM
    Kollinowens
    Kollinowens [OP] New Member
    Kollin
    2002 silver tundra SR5
    Hey everyone, I’m having some trouble figuring out what the problem is. My 4.7L V8 is stumbling on idle and under heavy load. Trying to alleviate the problem I’ve changed the fuel filter, new spark plugs, boots, and air filter and it still seems to do it, and I can’t find out what the problem is, and It’s throwing no codes. If anyone has had this issue before and found a solution please let me know!!
  2. May 22, 2020 at 9:37 PM
    Hughjanice
    Hughjanice New Member
    Hieu
    2015 Toyota Tundra CM 4x4
    Two single led light bars behind grille, bak revolverx2, fn 18" wheels, bfg ko2. 46gal transfer flow tank.
    Clean mass air flow sensor, Check engine compression, cylinder leak down test and check fuel pressure. If no problem found, exhaust back pressure test for possible clogged catalytic converters.
    what kind of mileage do you have on the truck?
    When was your last oil change?
  3. May 22, 2020 at 10:24 PM
    Kollinowens
    Kollin
    I got an Oil Change close to a month ago, and the truck has close to 230,000 miles.
  4. May 23, 2020 at 5:44 AM
    Professional Hand Model
    Hand Protectors
    Possibly look at a Throttle Body Cleaning and check your Ignition Coils for failure/cracks.
  5. May 24, 2020 at 12:05 AM
    Kollinowens
    Kollin
    Okay, will do. Thank you!
  6. May 24, 2020 at 5:16 AM
    Hooptytrix
    Hooptytrix Squeaky Chicken
    Dirty South
    2000 AC 4x4, 2001 AC 4x4 Sold. 2005 DC SR5 2WD
    Have you done your timing belt?
  7. May 24, 2020 at 10:23 AM
    Kollinowens
    Kollin
    My timing belt is on order right now, should be getting it done in the next week or so.
    bmf4069 likes this.
