Engine starts but can't get out of park. Also no lights or AC.
Discussion in '2.5 Gen Tundras (2014-2021)' started by Jlkinsey88, Jun 20, 2021.
  1. Jun 20, 2021 at 3:38 PM
    Jlkinsey88
    Jlkinsey88 [OP] New Member
    Jared
    2020 white tundra sr5
    HELP ME. 2020 tundra tss. Drove my truck to my sons baseball game and came home. Then went to leave a few hours later and the truck is starting but not working. Trucks engine starts perfect but nothing else works. No lights no AC pretty much nothing inside. Won’t even let me out of park. Not sure what it is. Any help appreciated. Thank you.
  2. Jun 20, 2021 at 3:51 PM
    Wallygator
    Well that's weird. Hope you can get it working or it's a tow truck to the dealer.
    Jlkinsey88[OP] likes this.
  3. Jun 20, 2021 at 3:55 PM
    2mchfun
    Sounds like a loose ground wire somewhere maybe.
  4. Jun 20, 2021 at 4:18 PM
    TundraTed
    TundraTed New Member
    2020 SR5 TRD Sport Crewmax 4x4
    In order: Orvis dog cover for rear bench seat, OE gun safe, Husky liners front/rear, Tyger tonneau tri fold, Rough Country seat covers
    I’d check the fuse box relays. Good luck
  5. Jun 20, 2021 at 4:20 PM
    atomheart
    atomheart New Member
    2021 Tundra 4x4, 5.7L
    hayden trans cooler eibach 2.0 roadmaster active suspension hd dd bamuffler 10"
    I had a slightly similar scenario with a Kia Soul – turned out to be the instrument cluster.
    I drove ~ 30 minutes after getting completely soaked (walked through a heavy downpour - rain gear defeated) during a very humid and rainy week.
    The car sat for several days (windows were still fogged from cabin humidity) and when I went to drive it again it wouldn’t get out of park and the instrument cluster was dead (no gas gauge, engine light cycle, etc). The cluster dried out about two weeks later and all was well.
  6. Jun 21, 2021 at 12:06 PM
    2mchfun
    Verdict??
  7. Jun 21, 2021 at 1:57 PM
    GasGuzzler
    GasGuzzler New Member
    2019 Tundra
    6” Readylift AMP Research Power Step Sides Fuel Grenade wheels Toto Tire Complete Stereo Overhaul
    I have had this exact same issue. Mine was due to the 12 Volt Solutions auto starter. I simply had to reprogram it.
  8. Jun 23, 2021 at 2:07 PM
    Jlkinsey88
    Jared
    Toyota is saying they think it is the remote start that the other dealership had installed. They had carrots who installed it come put it back to stock. But one of the main fuses was blown so they had to order one.
    2mchfun likes this.
  9. Jun 23, 2021 at 2:08 PM
    Jlkinsey88
    Jared
    Auto starter like a remote start?
    Nvm just looked them up. Hopefully that’s my situation and a easy fix.
    2mchfun likes this.
  10. Jun 23, 2021 at 3:17 PM
    GasGuzzler
    2019 Tundra
    Just know that the remote start is not necessarily bad so don't have them pull it off. The re-program is pretty easy.
  11. Dec 8, 2024 at 6:56 PM
    Elloco007
    Elloco007 New Member
    Luis
    Hi everyone, please help same issue here
    Truck starts just fine but can't shift to drive , all dashboard lights are off no power at all , I did tried multiple times turn off and on engine and fix the problem and once I parked it goes back to the same problem, any idea what it could be
    Thank you everyone (by the way I'm new to this forum)
    I have a 2018 tundra sr5 60k miles
  12. Dec 10, 2024 at 2:49 AM
    blanchard7684
    blanchard7684 New Member
    sounds like a valet mode, immobilizer, or remote start malfunction.
  13. Dec 10, 2024 at 6:29 AM
    koditten
    Kirk
    Midland of the Mitten
    Check your taillights.
    If that fuse is blown, truck won't come out of park.
  14. Dec 10, 2024 at 8:36 AM
    Elloco007
    Luis
    I have a after market remote starter but it was installed a year ago so why problems right now?
  15. Dec 10, 2024 at 11:29 AM
    2mchfun
    Main fuse was the culprit mentioned in post #8 up above your post.
    koditten likes this.
  16. Dec 11, 2024 at 7:53 AM
    Elloco007
    Luis
    Problem fixed , bad wiring on my after market remote starter was making bad connection.
    KNABORES and koditten like this.
  17. Dec 11, 2024 at 8:01 AM
    Make no assumptions and follow the most likely route of failure. Glad you got it sorted.
