Engine stalled shifting R->D
Discussion in '3rd Gen Tundras (2022+)' started by Retroboy1989, Apr 1, 2025.
  1. Apr 1, 2025 at 5:12 PM
    Retroboy1989
    Retroboy1989 [OP] 'Course it's 4x4!
    Northern Utah
    2012 SR5 TRD OR (prev) 2025 SR5 TRD Rally (now)
    I had just backed out of my driveway, paused for a second, then shifted directly from R to D.
    The truck lurched forward and then nothing. It's almost like I had dropped the clutch while holding the brake at idle. Just a thud and it was silent.
    It restated just fine and I was able to go run it at highway speeds without and issue.
    Any thoughts? I cannot replicate it.
  2. Apr 1, 2025 at 7:29 PM
    chrisgibbs707
    chrisgibbs707 New Member
    Socal
    2022 Tundra SR5 4x4
    Similar thing happened on my grand Cherokee after getting the timing chain cover gasket replaced. Turned out the dealer broke the thermostat, but with your truck being brand new, maybe it’s just a loose connector somewhere. Did you scan for any codes?
  3. Apr 1, 2025 at 9:13 PM
    Retroboy1989
    Northern Utah
    Lots of noise. No major codes from what I see.
    I cleared everything and will drive it to see what happens :notsure:
    ABS:
    C14FE14 - Steering Angle Sensor Supply Voltage: Circuit Short To Ground or Open
    Heater & air conditioning:
    P007015 - Ambient Air Temperature Sensor Circuit: Circuit Short To Battery or Open
    Body/convenience system:
    U023087 - Lost Communication With Rear Gate Module: Missing Message
    Instrument cluster:
    U023587 - Lost Communication With Cruise Control Front Distance Range Sensor Single Sensor or Center: Missing Message
    Parking sensors:
    C1AE187 - Manufacturer-specific code
    (tap to search)
    C1AE287 - Manufacturer-specific code
    (tap to search)
    C1AE387 - Manufacturer-specific code
    (tap to search)
    C1AE487 - Manufacturer-specific code
    (tap to search)
    Telematics:
    U014087 - Lost Communication With Body Control Module: Missing Message
    U015587 - Lost Communication With Instrument Panel Cluster (IPC) Control Module: Missing Message
    Entry / smart key:
    Airbags:
    Lane-keeping assist 2:
    Power source control:
    U114F87 - Manufacturer-specific code
    (tap to search)
    High beam assist:
    All-round vision camera:
    C168187 - Manufacturer-specific code
    (tap to search)
  4. Apr 1, 2025 at 10:01 PM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    2022 CMLB TRD OR Prem. 4X4 and 2002 RCLBV65Spd
    I've had mine almost stall if I immediately put it in drive after I start it and just tap or blip the throttle. The rpms would drop well below idle then come back up to party.
  5. Apr 2, 2025 at 4:50 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Had to bring it as is to dealer, so they read the codes themselves and add it to your case.
  6. Apr 2, 2025 at 4:53 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Looking at the codes, it is either voltage drop and blocks rebooting, or CAN-bus interruption that is caused by failing block.
  7. Apr 2, 2025 at 4:55 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    If Denso didn't drop the ball, their ECU will keep the engine running until it is physically impossible. I did all kind of crap to CAN-bus in one of my cars, engine ECU lost everyone and sat in isolation, yet the engine was running. In limp mode, yes, but running.
  8. Apr 2, 2025 at 1:41 PM
    Retroboy1989
    Northern Utah
    I had started the engine with the grill removed as I was installing the transmission cooler to test for leaks. I got all kinds of malfunction indicators and offline warnings at that time. The grill houses the parking sensors, radar, radiator louvers, and fog lights. Plenty to throw codes.
    I have cleared the codes to start clean slate to see what happens.
    I have driven the truck half a dozen times with 50-60 miles since it stalled with no hint of an issue. Ill retrieve codes after a few weeks go by and I will leave them for the dealer to read this time, if any.
  9. Apr 4, 2025 at 8:34 PM
    FleecingOilyRansomDealer
    FleecingOilyRansomDealer New Member
    2023 SR5
    It’s designed to do that to be fail operational To prevent the vehicle from being disabled in the highway. But once you shut it off that way, it will likely refuse to start
  10. Apr 4, 2025 at 8:48 PM
    pursuit2550
    pursuit2550 New Member
    2020 Tundra SR5 Maggie 1900
    I saw a mechanic diag a newer Accord no start issue. Turned out that a failed LED headlight module wouldn't let the vehicle start. I dont know who's bright idea it was to run every single thing through a ECM and if just 1 thing fails, it takes the whole network down.
  11. Apr 5, 2025 at 5:47 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    In limp mode you are lucky if you can get up to 10 MPH, in like two minutes. Hills are barred, simply no power to climb them. You still can get out of the way and have some heat in the cabin.
  12. Apr 5, 2025 at 7:20 AM
    Retroboy1989
    Northern Utah
    It's been a few days with plenty of drive cycles.
    No issues so far.
    Ill retrieve codes in the next few days.
  13. Apr 7, 2025 at 11:28 AM
    24LTD
    24LTD New Member
    Happen to me when cold start and drive.
