Engine Squeaks-Belts or?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Rocko9999, Feb 15, 2021.
  1. Feb 15, 2021 at 2:00 PM
    Rocko9999
    Rocko9999 [OP] New Member
    I just started hearing these squeaks from the front the engine. Not sure if it's the belt or pulley/tensioner? Anyone recognize this sound?
    https://youtu.be/I7ghUHskmIo
    2014 4.6L 155K miles.
  2. Feb 15, 2021 at 2:09 PM
    JeffMac
    JeffMac 2 Words, 1 Finger
    Jeff
    South Florida
    2015 Black Tundra OVTUNE
    Suspension: Bilstein 6150 Front Max Setting CB Shim 2x Driver 1x Passenger Bilstein 5160 Rear CB +3 Shackles Firestone Airbags w/ Daystar Craddles Engine: OVTUNE - 87 w/ Torque Modifier SABM w/ K&N Filter TB Coolant Bypass Fumoto Drain Plug Wheels/Tires: ProComp Bandidos 0mm Offset Nitto Exo Grappler AWT 285/70/18 Exterior: TRD Pro Grille Spyder Headlights/Taillights Ecoological Bumpershellz LED everything Tinted windows Bakflip MX4 Tonneau Cover K-Source Tow Mirrors Interior: Pioneer AVH-W4500NEX Radio 2x 10” Pioneer Subwoofers 1200W Pioneer Mono Amp 2000W Pioneer 4 Channel Amp
    :popcorn: My 15 5.7 55k miles does this in the cold while its warming up then goes away. Watching along.
    Rocko9999[OP] likes this.
  3. Feb 15, 2021 at 8:55 PM
    BigAl
    BigAl New Member
    2014 SR5 Magnuson SC
    Mine does too! Following.
  4. Feb 16, 2021 at 2:53 AM
    Adam New Member
    check you belt, idler pulley and tensioner. A replacement of said items would probably get rid of that noise. If not, there is may be another bearing pully going bad like on alternator or something.
    HulkSmurf14 likes this.
  5. Feb 16, 2021 at 4:03 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Tensioner...I have replaced mine 3 times over 1 year warranty using an aftermarket and the shop was tired of mine and others constantly needing replaced. I ended up swapping in an OEM tensioner and it's been waaaaay better even in the cold...the cost was roughly $150 all in, including labor. Piece of mind to get it repaired! I just breached 65k miles on a SC'd 5.7 for reference...
  6. Feb 16, 2021 at 4:37 AM
    timsp8
    NY
    What he said. My 2010 went through a few tensioners. I have the squeak on my 18 when cold but it goes away after warming up.
  7. Feb 16, 2021 at 4:38 AM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    Tensioner
  8. Feb 16, 2021 at 4:42 AM
    Infernotundra17
    Infernotundra17 2017 Inferno SR5 Crew Max
    Martin
    Las Vegas, Nevada
    2017 Tundra Inferno orange
    Black Rhino 20" Go Rhino RB20 steps Magnaflow muffler
    Tensioner pulley for sure ,had 2 change both pulleys and did the belt too myself.Not a horrible job .Cost me about $150.00 Amazon or others sells a kit for just that.
  9. Feb 16, 2021 at 8:23 AM
    Rocko9999
    Thanks. Was your squeak similar and did it cure it?
  10. Feb 16, 2021 at 8:32 AM
    HulkSmurf14
    2014 Tundra Limited
    Identical sound on mine...
  11. Feb 16, 2021 at 4:45 PM
    Infernotundra17
    Martin
    Las Vegas, Nevada
    Mine was the same noise .
  12. Oct 25, 2021 at 5:24 PM
    Rw429
    Rw429 New Member
    Rob
    2017 Black Toyota Tundra SR5 Crewmax TRD Off Road
    Same noise when cold or after heavy rain. It goes away within 30 seconds.
  13. Oct 25, 2021 at 5:36 PM
    HulkSmurf14
    2014 Tundra Limited
    Spend $130 and buy the part and fix it yourself or spend $200 and have someone else do it...it will get worse as we are entering the older months and bother you more...
  14. Oct 25, 2021 at 5:50 PM
    Jhon
    Jhon New Member
    On the Oregon Trail
    2021 SR5 TRD OR
    If that were a Hemi it would be called normal. On a Toyota as stated probably a belt tensioner.
    Rw429 likes this.
