Engine replacement
Discussion in '1st Gen Tundras (2000-2006)' started by Arlott1, Jul 25, 2024.
  1. Jul 25, 2024 at 5:32 AM
    Arlott1
    Arlott1 [OP] New Member
    2005 Silver Tundra DC SR5
    Hello, can anyone direct me to a previous thread on a step-by-step for pulling an engine?
    I’m about to start a swap as my engine is seized. Also, any additional details on what’s involved specifically that it’s seized, as I won’t be able to turn the crank to access bolts… I may have to remove the transmission with it?
    thanks!
  2. Jul 25, 2024 at 6:02 AM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    Arlott,
    Welcome to the forum!
    The search function will help you find what you are looking for. Be warned that nobody is going to have a step by step for you, but the community here is more than happy to work on any specific questions that you have. Pictures help with questions and details.
    I would either:
    A. pull the heads and see if the engine rotates.
    B. Pull the engine/trans as a unit.
    Good luck and post pictures! We like pictures!
  3. Jul 25, 2024 at 6:59 AM
    Arlott1
    o_O
    thanks for the reply!
    I’m shocked that at this point, nobody would have a step-by-step of an engine being pulled out! That’s crazy considering how many people are on here and how long this forum has been around o_O
    I’ll do my best to document everything and maybe it will help someone else out in the future :)
  4. Jul 25, 2024 at 7:05 AM
    That’s cause the 2UZ isn’t known for grenading. It’s a pretty rare occurrence. Agree with previous poster saying to pull the heads. Surely the crank isn’t locked up?
    bmf4069 and JakeJake like this.
  5. Jul 25, 2024 at 8:16 AM
    shifty` In South Dakota Trouble ain't hard to find
    Lasat person I saw swap their engine due to "no compression" on a cylinder pulled his engine for a higher-mile engine, only to tear down the low-mile engine with the "no compression" to find the cause was a simple stuck valve, which could've been remediated without pulling the engine.
    Then he went to swap the new high-mile engine in, and had issues getting it running. Not long after, he disappeared from the forum.
  6. Jul 25, 2024 at 8:37 AM
    3bears
    3bears New Member
    Joshua
    fairbanks alaska
    2002 acess cab
    none yet
    havent checked but what about youtube
  7. Jul 25, 2024 at 9:21 AM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    2003 V8 SR5, Access Cab, 4x4, White
    You may want to download copies of the Service Manuals, in case they ever go away. For you, the 2005-2006 FSM / in case others may want it, 2000-2003 FSM
    credit to @shifty`
    You also might want to purchase a Haynes Repair Manual.
    JasonC. and shifty` like this.
  8. Jul 25, 2024 at 2:05 PM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    TX
    2001 4x4 4.7L “Best Cab”/AC Limited 51k mi
    Was going to say exactly this. That Full Service Manual is a beast and will probably get you 90% of the way there.
    ATBAV8[QUOTED] likes this.
  9. Jul 26, 2024 at 10:12 AM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    Probably no one has a step by step documentation is that because it’s fairly simple to remove the engine? At least that’s my guess. I’ve had the engine in and out a few times on both my tundras. The engine bay has plenty of working room, so it’s pretty darn easy. FYI, the engine wire harness is designed in such a way that it stays attached (and therefore gets removed with) to the engine. It actually makes it pretty easy with that design. Take a read through my thread. I briefly cover my engine swap. You might be able to glean some pro tips from it..
    https://www.tundras.com/threads/tacoed-tundra-project.130491/
