Engine replacement, now A/C is warm
Discussion in '3rd Gen Tundras (2022+)' started by Tbag1118, May 27, 2025 at 11:56 AM.
  1. May 27, 2025 at 11:56 AM
    Tbag1118
    Tbag1118 [OP] New Member
    TJ
    2022 tundra limited crewmax
    I had my engine replaced last week and now my A/C is blowing cool out of the driver vent and warm out of all other vents. On start up the A/C makes a Darth Vader noise too. Can anyone explain this? Thanks!
  2. May 27, 2025 at 12:05 PM
    They did something wrong / forgot something. Take it back.
    Yaboy, NewImprovedRon, raylo and 6 others like this.
  3. May 27, 2025 at 2:22 PM
    VCheng
    VCheng New Member
    Upstate NY
    Factory installed self-destruct device :D
    They forgot to charge the system, and the noise is because the compressor is starved of oil, likely causing internal damage. I would ask for a new compressor, new desiccant, and a proper charge after an overnight leakdown test. That would be the proper repair. Anything short of this would lead to more headaches down the road.
  4. May 27, 2025 at 2:45 PM
    Fatone
    Fatone New Member
    2022 Tundra TRD Sport Premium
    blend door actuator problem?
    Impacts air flow and can make noise.
    Soflo and dondino like this.
  5. May 27, 2025 at 2:58 PM
    Mr Badwrench
    Mr Badwrench New Member
    As much as you are probably sick of dealing with them by now, yes, take it back to them.
    NewImprovedRon likes this.
  6. May 27, 2025 at 4:27 PM
    Tbag1118
    TJ
    It's only been a couple days. You think that short time could cause damage?
    ZappBrannigan likes this.
  7. May 27, 2025 at 8:57 PM
    VCheng
    VCheng New Member
    Upstate NY
    Very likely. You still have some residual refrigerant in the system since you have some cool air being felt but compressors do not like moisture or being low on lubricant which is dispersed by the refrigerant. The proper procedure to recover the old refrigerant and seal the system against moisture while the engine is replaced may not have been followed correctly.
    NewImprovedRon and ZappBrannigan like this.
  8. May 27, 2025 at 9:23 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Running anything without the proper lubricant can damage it in short order.
  9. May 27, 2025 at 9:41 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    So are you on the didn’t charge it train or theres a leak train? Two different scenarios.
    There would be no residual Freon left in the system to run the compressor off of a low pressure switch if they didn’t recharge it.
    The majority of compressor oil stays within the compressor.
    Tunrod likes this.
  10. May 28, 2025 at 12:57 AM
    VCheng
    VCheng New Member
    Upstate NY
    I’m saying “they didn’t charge it PROPERLY” based on the description. Whether it leaked out or not refilled in the first place is immaterial. The noise from the compressor is not a good sign for assuming adequate lubrication. The desiccant change is needed anytime the system is not closed off properly.
  11. May 28, 2025 at 4:43 AM
    raylo
    raylo not so new member
    Frederick, MD
    A/C systems have low pressure cutout switches so if the system was uncharged the compressor would not run at all.
    FrenchToasty and Tunrod like this.
  12. May 28, 2025 at 5:19 AM
    VCheng
    VCheng New Member
    Upstate NY
    True. One wonders how cool below ambient is the cool air from one side being reported without an actual vent temp.
  13. May 28, 2025 at 5:24 AM
    Tbag1118
    TJ
    I don't have a temp on the air, but if all vents were blowing the air that the driver side was I probably wouldn't have noticed. It's not ice cold like normal, but it's cold enough that I wouldn't have been alarmed. All other vents are blowing room temp air or warmer. I did switch to heat to see how that would work from the same vents and it got hot from all vents.
  14. May 28, 2025 at 5:28 AM
    raylo
    Frederick, MD
    If it is making noise (what is a Darth Vader noise??) I would not run it. Get it back ASAP and let them fix it. Opening the A/C system is one of my biggest worries with the engine swap. It will never be as reliable as if left alone. I wonder if they are even replacing the filter/dryer like you are supposed to anytime the system is opened? I doubt it because I believe it is in or part of the condenser on these vehicles.
  15. May 28, 2025 at 5:34 AM
    VCheng
    VCheng New Member
    Upstate NY
    The first step here would be to check the pressures in the system and scan for any codes, and then go from there.
  16. May 28, 2025 at 5:36 AM
    The only step here, is to take it back.
