Engine problem working
Discussion in 'General Tundra Discussion' started by Ndantunes, Jun 11, 2023.
  1. Jun 11, 2023 at 1:23 AM
    Ndantunes
    Ndantunes [OP] New Member
    Nuno
    Tundra TRD 2008
    Hello everyone, looking for help with my CrewMax TRD Off Road 08´ 5.7 3URFE , after hot it has a lot of difficulty starting it already replaces the fuel pump but it continues after it gets hot and stops for a while when I come back to put the engine on gear takes a long time to work, has anyone had the same problem
  2. Jun 11, 2023 at 4:29 AM
    2mchfun
    Welcome from OKC! Check for codes using obd scanner. You could have weak battery or bad cables/connections. There's lots of diagnostics you can do, but start with obd scanner.
