Engine Major misfire and lights coming on
Discussion in '2nd Gen Tundras (2007-2013)' started by stratos, May 24, 2023.
  1. May 24, 2023 at 4:13 PM
    stratos
    stratos [OP] New Member
    2010 Tundra 4X4 - 5.7L V8
    Hello everyone! New user here, finally come to asking for some opinions on what this is!
    So around a month ago my truck started severely misfiring in all cylinders. I just put brand new spark plugs in about 20K miles ago and all my plug wires and fuel injectors look fine. But the truck is only running about 500 rpm and very rough. 4LO is flashing along with the VSC light on, check engine (solid, not flashing surprisingly), and my battery voltage is jumping between 8-12 V (brand new battery).
    My OBD II reader only reads the 8 misfire codes and nothing else. I pulled out all the plugs and there are no access oil on them and seem to be working fine.
    I’m kinda stumped on this, any help or suggestions would be greatly appreciated!
    Thanks!
    _____
    From code reader:
    P0351 - Ignition Coil "A"
    P0354 - Ignition Coil "D"
    P0356 - Ignition Coil "F"
    P0357 - Ignition Coil "G"
    P0300 - Random/Multiple Misfire Detected
    P0305 Cylinder 5 Misfire Detected
    P0306 Cylinder 6 Misfire Detected
    P0351 Ignition Coil "A" Primary Control Circuit/Open
    _____
    SOLUTION!!!
    at least for me
    So it turns out that I had put one of the ignition coil connectors on backwards, causing my plug wires to short out and actually kept the other 3 cylinders on that side from running. This on top of having a bad ignition coil is why I had a total of 4 cylinders misfiring.
    To fix, make sure your plug wires look like the image below.
    If looking at it from the side, the color code on the wiring should be red/black, green/black, black/yellow, and yellow/black.
    If you continue to have issues, I'd highly recommend just replacing all of your ignition coils. Mine still has 7 of the OEM factory ignition coils at 275,000 miles, but likewise could have one go bad, especially if you forget to put the rubber seal back on (like me).
    Hope this helps!
  2. May 24, 2023 at 4:15 PM
    stratos
    Forgot to mention, I did a compression check on all cylinders about 2 months ago before the issue started. No leaks were found and everything seems normal. Truck ran for about a month after this and then all hell broke loose.
  3. May 24, 2023 at 7:06 PM
    PhotoNerd
    PhotoNerd New Member
    Tony
    Waterford, CT
    2008 Salsa Red Tundra DC SR5 4x4
    Chrome delete, Sequioa grill, bed lights, LED + head, fog & tail lights, Dynamat throughout, front & rear cameras, Pheonix PX6 13" head unit, 8" subwoofer, JBL speaker upgrades, tonneau cover, custom shifter, steering wheel cover
    I'm no expert but I'd troubleshoot the voltage first. There must be a problem with the battery and/or alternator if the voltage is dropping to 8V, right? And low voltage could cause other problems.
    I dunno I know nothing.
    TXBrit likes this.
  4. May 24, 2023 at 7:13 PM
    Nbab23
    Nbab23 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    Stillen CAI, DD 8” exhaust, Toytec Aluma coilovers, Icon leaf springs, SCS SR8 18x9 wheels, Cooper Rugged Trek 275/70/18 A/T Tires, Ecoological bumper shellz and grill surround, AJT interior black out kit, AJT shift knob. TRD pro style grill, VLED aqua blue footwell lights, MESO custom dome and map LED lights, swing case, Rough country bed mat, TRD pro headlights and fog lights, Morimoto XB tail lights and 3rd brake light.
    Could it be the ignition coils? I know they are involved in voltage and will cause a misfire when going bad. I've never heard of all of them going at once though, usually its just one or two at a time.
  5. May 28, 2023 at 6:11 PM
    stratos
    @Nbab23 @PhotoNerd Thanks for your responses! I plugged in a diagnostic computer again and got these codes...
  6. May 28, 2023 at 8:28 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    1st guess would be to check the battery ground cable.... 2nd would be check for damaged wires by rodents. May need to chase down wiring
    TXBrit and Rodtheviking like this.
  7. May 28, 2023 at 9:53 PM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    Check your crank and cam sensors.
  8. May 28, 2023 at 10:02 PM
    Leek128
    Leek128 New Member
    Bucks PA
    Had a Honda Accord throw similar codes ended up being a bad/clogged fuel injector. Try unplugging 1 injector at a time confirm engine stumbles ea time.
  9. Jun 20, 2023 at 9:26 AM
    drh2011xspCM
    drh2011xspCM New Member
    2011 Crexmax XSP
    OP any solution to this? I have the same issue, coils plugs checked, TPS replaced. Still same issue.
  10. Jun 20, 2023 at 9:38 AM
    stratos
    No unfortunately, still trying to diagnose but no luck. Only thing I can think of is to start pulling wiring and checking grounds. Maybe some rats or something got into mine. I’ll keep this updated if I find a fix!
    drh2011xspCM[QUOTED] likes this.
  11. Jul 6, 2023 at 8:59 AM
    stratos
    Still no solution. Anyone have suggestions please help! Thanks
  12. Jul 6, 2023 at 9:19 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Vacuum leak???
    Start the truck and start spraying carb cleaner around intake, intake manifolds and all vacuum hoses
  13. Jul 11, 2023 at 3:09 PM
    stratos
    Found a solution!! Check the original post! Turns out my plug wire connector was turned backwards, causing my plug wires to short out on 3 cylinders. Give yours a look!
