Engine lights on trac off VCF 4LO
Discussion in '2nd Gen Tundras (2007-2013)' started by Jhayxian, Jun 25, 2019.
  1. Jun 25, 2019 at 8:37 AM
    Jhayxian
    Jhayxian [OP] New Member
    This came on last week.
    (5.7 crew)
    Seen on YouTube disconnect battery terminal.(did that) next morning came back on again
    Check gas cap and found rubber o ring gasket were cracked..replace it from old rav4 caps. Disconnect battery term. It was fine for almost a week then this morning those lights WENT ON again!
    Whats going on???
    Help...
  2. Jun 25, 2019 at 7:00 PM
    What engine light is on?
  3. Jun 25, 2019 at 7:13 PM
    Buck0721
    Buck0721 New Member
    2012 Tundra 4.6L V8
    I have a 2012 with the 4.6L engine. I had the same lights the other day and it went into limp mode. Scan shows secondary air injection problem. I will be getting a by pass kit very soon.
  4. Jun 26, 2019 at 11:26 AM
    Jhayxian
    Looks like im getting same problem.when scanned it p2440 and read that it is air injection..5.7 2007 injection located between manifold and firewall..its going be expensive :(
  5. Jun 26, 2019 at 11:36 AM
    Buck0721
    Buck0721 New Member
    2012 Tundra 4.6L V8
    Mine also came up P2440 and P1604 all related to the air injection. I just ordered the by pass kit from Hewitt- Tech for $349.00. The Toyota tech at the dealer told me today that the kit does work and one of the techs actually installed it on his Toyota and hasn’t had any problems for over a year. You might want to go that route too.
  6. Jun 26, 2019 at 11:39 AM
    Buck0721
    Buck0721 New Member
    2012 Tundra 4.6L V8
    Keep in mind too that I’m in Virginia so I don’t have to pass an emissions test. It may still pass emissions anyway since the injection system only works for a minute or two at start up. That may be a question better suited to the company though.
