Engine light on
Discussion in '1st Gen Tundras (2000-2006)' started by May, Sep 16, 2024.
  1. Sep 16, 2024 at 12:15 PM
    May
    May [OP] New Member
    2006 Toyota Tundra
    None
    Yesterday went to Auto Zone to see why engine light on. Tested and said dirty cables, cleaned cables and today engine light came back on.
  2. Sep 16, 2024 at 12:16 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    What cables?
  3. Sep 16, 2024 at 12:17 PM
    May
    May [OP] New Member
    2006 Toyota Tundra
    None
    The battery cables
  4. Sep 16, 2024 at 12:17 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    What codes
    Jack McCarthy likes this.
  5. Sep 16, 2024 at 12:18 PM
    May
    May [OP] New Member
    2006 Toyota Tundra
    None
    Took to dealer a few days ago and they ran checks and Saud it was fine, no issyes
  6. Sep 16, 2024 at 12:19 PM
    May
    May [OP] New Member
    2006 Toyota Tundra
    None
    Can't figure out why light is on again.
  7. Sep 16, 2024 at 12:23 PM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    Your check engine light was on when you went to the dealer, and they said it was fine?
    If you go somewhere to get your check engine light looked at, the scan tool will give you a number such as P0301. Whatever error number the tool spits out, you can then google it and it will tell you what part of your truck is having issues. If you post the number here, we can give you advice on how to possibly fix it.
    Also note your truck also has a "Maintenance Required" light, which is different from the check engine light. The Maintenance Required light tells you that you have driven enough miles for your oil to need to be changed. This light has to be manually reset whenever you have your oil changed.
  8. Sep 16, 2024 at 12:24 PM
    May
    May [OP] New Member
    2006 Toyota Tundra
    None
    Thank you
  9. Sep 16, 2024 at 12:29 PM
    Jack McCarthy
    Bill
    North of Boston
    An auto parts store will typically read the code for you for free. They won’t clear it though. You need your own code reader or have a shop do it once they fixed the problem.
  10. Sep 16, 2024 at 12:31 PM
    May
    May [OP] New Member
    2006 Toyota Tundra
    None
    Thank you
  11. Sep 16, 2024 at 3:19 PM
    Is it the engine symbol light or "maintenance required" light? They're two different lights with two different meanings.
    Maintenance light is a dummy reminder you can reset, more info here, scroll down ot the video: https://www.tundras.com/threads/maint-required.148266/
    Engine symbol means something is wrong with the car, and as you found, any auto parts store can help you pull the codes.
    des2mtn likes this.
