Engine idle in park
Discussion in '2.5 Gen Tundras (2014-2021)' started by eagleguy, Feb 18, 2022.
  1. Feb 18, 2022 at 1:27 PM
    eagleguy
    eagleguy [OP] New Member
    Is it just me or does te Tundra idle rather high when started in park? Drivetrain does not clunk when put in gear like an older car might but idle seems a bit high.
  2. Feb 18, 2022 at 1:35 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Idle higher on cold start than when the engine is fully warmed up? Yep. Sho duz.
    Cpl_Punishment likes this.
  3. Feb 18, 2022 at 1:44 PM
    eagleguy
    I am in Florida so its never that cold. Idle always high on start up!
  4. Feb 18, 2022 at 1:45 PM
    Seafury
    Seafury Kickin names, and takin ass!
    Agent K
    SC Low Country
    2014 White 1794 "SnowWhite aka the Frost Queen"
    Bilstein 6112/5160, 3 CB front shims, SPC UCA's, CB +3 rear Shackles, total 3/2 lift, Dif drop, CB Carrier bearing drop, Fortin Evo One remote start from Tech12volts PnP, AMP research Powersteps PnP, Vent shades, Tinted windows, Black/Red lined cupholder inserts, Proclip USA dash phone mount with Scosche Magic Mount wireless magnetic phone charger, Stock wheels/tires for now.
    I am not exactly sure what triggers the "cold start" operation, but it may not be just temperature.
    It may be time based or idk.
    Anyone know for sure?
  5. Feb 18, 2022 at 1:49 PM
    timsp8
    NY
    Unless it’s 200F out, your truck always cold starts when it’s been sitting for awhile.
    Cpl_Punishment and biebs96 like this.
  6. Feb 18, 2022 at 6:21 PM
    BigdaddyII
    BigdaddyII New Member
    South Louisiana
    2019 Ram 1500
    Sounds like a jet preparing for takeoff! My 2002 Tacoma did the same thing. No Ford, Dodge, Honda, or Nissan that I’ve owned in between has done it quite so dramatically.
  7. Feb 18, 2022 at 6:32 PM
    THinTX
    THinTX New Member
    Tony
    2018 MGM DC 4X4
    Idle speed is relative to coolant temperature. Higher idle = faster warmup = faster heating of cats to lower emissions.
    Edit: There is also a default idle/throttle position that will be adjusted accordingly based on coolant temp shortly after startup.
    HulkSmurf14 likes this.
  8. Feb 18, 2022 at 6:50 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Loops until ready...
  9. Feb 19, 2022 at 1:23 AM
    eagleguy
    Thanks for the feedback as I thought I needed to take a trip to the dealer!
  10. Feb 19, 2022 at 5:33 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Doesn’t matter. Unless the engine is at or close to operating temp, it’s going to high idle at startup. If it’s 90* outside and the trucks been sitting over night, it’s still going to high idle at startup since 90* is still a “cold” motor.
  11. Feb 19, 2022 at 5:46 AM
    eagleguy
    I am used to being able to kick it down or have it go down by itself. Seems it stays high too long.
  12. Feb 19, 2022 at 5:50 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    In addition to what the others have said, the roar you hear is the air injection pumps, I believe.
  13. Feb 19, 2022 at 6:01 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    All Toyota trucks do that since at least the 80s...part of the 'noise' is the mechanical fan...
