Engine feedback through my subs
Discussion in 'Sequoia 3rd Gen (2023+)' started by Bassmaster34, Feb 25, 2025.
  1. Feb 25, 2025 at 8:30 PM
    Bassmaster34
    Bassmaster34 [OP] New Member
    2024 Sequoia TRD Limited
    Sub and amp
    Hello,
    I am new to this forum but I am hopeful someone here can help me. I recently had an amp and sub installed in my 2024 Sequoia. I am getting a rhythmic thump through the sub when I drive. I am told it is from the exhaust audio that is fed into the rig. It seems like the fix is to disconnect the ANC but I cannot find anything that tells me where it is. Has anyone else had this issue and if so what did you do?
  2. Feb 26, 2025 at 8:49 AM
    manofsteele2003
    manofsteele2003 New Member
    Grant
    24 Sequoia TRD Pro
    Westcott designs 3"/1" lift 295/70/18 Falken Wildpeak RTs Canvasback cargo liner aFe Tow hooks
  3. Apr 18, 2025 at 7:34 AM
    s2kroma
    s2kroma New Member
    Roman
    2024 Toyota Sequoia Limited 4WD
    None
    Carista works great for turning off fake exhaust noise inside the truck and you can also disable alarms for the seat belts.
