Engine fan
Discussion in 'General Tundra Discussion' started by mohd.darmaki, Aug 31, 2018.
  1. Aug 31, 2018 at 1:42 PM
    mohd.darmaki
    mohd.darmaki [OP] New Member
    Mohammed
    1794 platinum Black model 2017
    Honey-D kit , sos performance lowering kit , TRD daul exhaust , front & rear sway bars ,TRD Air Intake , TRD Pro Grill/Hood Bulge , 2018 Front lights/ Fog lights , Fuel marveick wheels 20x12 negattive44 with grapper 305 tires , Glossy Black Door Handles Cover Half mirrors tailgate w cam, Tundra Steep foot; Fridge center console ,Tundra black Tailgate Trim Bezel , 4x4 Tundra tail , cup olders , Disk Brake Calipers Cover , TRD Liscense Plate , kuda mount black, Super Charger
    hello guys
    Whats the difference between push fans and puller fan
    Am i wanna install 2 fan for my Tundra Supercharger 5.7 2017 the weather goes upto 50... but not sure what shoul i get abd should they be installe with ac or alone stand with a button or with thermostats automatic.
    What is good company and what type i should go for push or pull
    Pls share with me you comments into this issue
  2. Aug 31, 2018 at 1:58 PM
    mohd.darmaki[OP] likes this.
  3. Aug 31, 2018 at 2:06 PM
  4. Aug 31, 2018 at 2:08 PM
    mohd.darmaki
    Mohammed
  5. Aug 31, 2018 at 2:08 PM
    Hey Mohammed. If you replace the engine fan, a set of puller fans will be needed.
    I would use thermostat control and have manual override switch.
    Black Wolf likes this.
  6. Aug 31, 2018 at 2:11 PM
    See the above^^^^^^heh..heh.
  7. Aug 31, 2018 at 2:11 PM
    mohd.darmaki
    Mohammed
    Hi sir am not sure if candian spec or overall tundra comes with fans
  8. Aug 31, 2018 at 2:12 PM
    ColoradoTJ likes this.
  9. Aug 31, 2018 at 2:13 PM
    I think did too. He should be able to help.
  10. Aug 31, 2018 at 2:15 PM
    He has, I remember seeing a thread n pics on it
  11. Aug 31, 2018 at 2:15 PM
    mohd.darmaki
    Mohammed
    :thumbsup:
    Ok i think i will go to the pusher ones
  12. Aug 31, 2018 at 2:20 PM
    What do you use on your JPs?
  13. Aug 31, 2018 at 2:25 PM
    I use Ford Taurus 3.8L two speed fans, relays, temp switches.
    I should have stayed with the mechanical engine fan.
  14. Aug 31, 2018 at 2:41 PM
    Vizsla
    Vizsla 2 = 2.5
    You have the transmission cooler, engine oil cooler, and transmission fluid warmer. Your truck has a fan. It gets to 50 where I live as well, many Tundras in the area supercharged also. I never hear about any cooling problems. This is current specs for all Canada 5.7 engines, but they did not change.
    mohd.darmaki[OP] and Black Wolf like this.
  15. Sep 1, 2018 at 12:11 AM
    mohd.darmaki
    Mohammed
    Your the best so ur not suggestting to install any extra fans
  16. Sep 1, 2018 at 5:57 AM
    MT Madman
    MT Madman Just an ordinary guy
    Hawk Point MO
    2020 Silver Platinum
    TRD dual exhaust TRD Rear Sway Bar SnugTop Hi-Liner
    Push! My neighbor had a pull fan and it let loose going right into and destroyed his radiator.
  17. Sep 1, 2018 at 6:02 AM
    That's exactly what he is suggesting.
