Engine Coolant replacement
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by PNJ 4x4, Sep 19, 2024.
  1. Sep 19, 2024 at 8:56 AM
    PNJ 4x4
    PNJ 4x4 [OP] New Member
    2018 TRD OFF ROAD
    I'm at 86k miles, 2019 TRD Pro. Do I need to takeoff the skid plate to drain the coolant??
  2. Sep 19, 2024 at 3:13 PM
    excelw
    excelw AfRo Samurai
    WW
    AB, Canada
    2019 Toyota Tundra TRD Pro (Midnight Black)
    leather wrap steering wheel, front window tint, ceramic coating, AMP research power steps, Toyo open country at3 35”x11.5x18, Volk Racing te37xt 18 9.5 0 offset, Rays formula II lug nuts Warn fender flares, Coachbuilder +3, bilstein 8112 front and 8100 double bypass rear, Kenwood excelon 996xr stereo +7” speakers Westcott designs front lift, RAS rear leafs, yota leds, NSV Lightbar
    I didn’t I used a 3/8” ID rubber hose through the oil filter door and drained into a pan. pretty sure it was 3/8” if i remember correctly
    CaptRussia253 likes this.
  3. Sep 19, 2024 at 4:35 PM
    Ericsopa
    Ericsopa Old man and the sea
    Reached mine through the wheel wells. No removal of anything. If I recall correctly, it was behind the skid plate and I drained into a large concrete mixing tub.
    I'm about to do mine again, so if my memory of the last time is incorrect, well, I'll just chalk it up to age.
  4. Sep 19, 2024 at 4:57 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    '18 Tundra TRD Sport 2WD 5.7 Crew Cab MGM
    With regards to the driver/passenger side block drains...I recall reading a post on here that suggested jacking up the drivers side of the truck and only needing to drain the passengers side block drain as the drivers side only drains a tiny bit and is harder to get at then the passenger side.
    Just a possible suggestion.
    vtl likes this.
  5. Sep 19, 2024 at 4:58 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    https://www.tundras.com/threads/coolant-replacement-the-easy-way.142235
  6. Sep 19, 2024 at 4:59 PM
    TacomaTRD4x402
    Southern California
    vtl[QUOTED] likes this.
  7. Oct 6, 2024 at 9:37 AM
    Ericsopa
    Just replaced the coolant on my '13 CM. So I was wrong. You do need to remove the pan. I'd forgotten .....that's what happens as one gets older. Even with pan removed, the coolant is going to run all over the suspension and frame components, so the big tub is necessary, unless you can push a vinyl tubing onto the fitting to direct the flow (too difficult to mess with). Getting to the passenger side not very bad...long extension with 10mm socket, going in front of the engine mount. Driver side required removal of the wheel, and going in behind the engine mount, using a u-joint before the socket due to the angle getting to the fitting. Both sides have some flexible inner fender linings to deal with.
    Tripleconpanna likes this.
  8. Oct 6, 2024 at 9:46 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    In the thread linked above there's a link to $10 fuel transfer pump that makes coolant replacement easy. Don't need to bend over at all.
  9. Oct 6, 2024 at 10:15 AM
    Ericsopa
    I just read that thread, and it's obviously very useful info. But I found that it wasn't really very hard, even for this near-80 yr-old. I'm thankful to be in pretty good shape for my age, but if a person should have physical challenges, then by all means, there are easier ways to do this. If age or injury is a factor, we often have to use our brains to make up for our loss of strength.
    And besides, I need to keep bending over as much and as long as I can. :D
    Tripleconpanna and Tunrod like this.
  10. Oct 6, 2024 at 10:18 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    I'd say (to 24 y.o myself): always use your brains to avoid injuries and loss of strength ;-)
  11. Oct 6, 2024 at 10:37 AM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    My 24yr old self wouldn’t have listened to adult me anyway…
    bflooks, Xcumminsguy and vtl[QUOTED] like this.
  12. Oct 6, 2024 at 10:42 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Yeah, mine would just say "F-k off" =) Young stupid idiot...
  13. Oct 7, 2024 at 6:14 AM
    Ericsopa
    To be honest, when I was about three years younger than your 24 y.o. self, I was invincible.....as were all the young warrant officer pilots under my command, flying choppers in VietNam. One might say we were young stupid idiots, too. But sometimes that's what it takes.
    Forgive my reminiscing ......
    Tripleconpanna and vtl[QUOTED] like this.
  14. Oct 7, 2024 at 6:17 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    No guts, no glory.
    Ericsopa[QUOTED] likes this.
