Engine Compatibility
Discussion in '2nd Gen Tundras (2007-2013)' started by WTreaty, Aug 25, 2025 at 11:59 AM.
  1. Aug 25, 2025 at 11:59 AM
    WTreaty
    WTreaty [OP] New Member
    Monday
    Hi, I know next to nothing about engines and was wondering if anyone knew if a 2019 3ur-fbe engine is compatible with a 2010 3ur-fbe engine. My 2010 engine recently broke down and I am trying to see if the 2019 model can replace my current one. The reason for asking is that while the mechanic I asked said that the engines should be compatible, however, the shop I am getting my engine from is saying that because the VIN#'s don't match up I would not be able to get the warranty for the engine, so I wanted to be sure.
    HulkSmurf14 likes this.
  2. Aug 25, 2025 at 2:15 PM
    D4x4TRD
    D4x4TRD New Member
    Định
    Va beach, VA
    2012 Sr5 DC TRD 4x4 Blaaaaaack baby 4.6liter
    Blacked out front grill badge Bigger tires 305/60r18 Tonneau cover
    I’m going to take a stab at this. Most likely no. You would need at least the same engine from the same generation truck 2010-2013. The newer generation engine will not have comparable wiring harnesses for the ecu and other components that go on the engine. It is safer to replace with the same generation engine. Good luck. Your mechanic should know the difference. I would worry if he didn’t.
  3. Aug 25, 2025 at 2:17 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    It'll work but you will need the ecu and harness to be more plug and play.
    Fobroader and Mdl like this.
