Engine Cleaning
Discussion in 'Detailing' started by pvn.beluga, Mar 1, 2021.
  1. Mar 1, 2021 at 1:05 PM
    pvn.beluga
    pvn.beluga [OP] New Member
    Phuc (Phooc)
    Connecticut
    Hey all,
    Spring looks like it's about to come and I think the engine bay is in need of cleaning. Has anybody cleaned their engine bay before? And what steps did you take?
  2. Mar 1, 2021 at 1:06 PM
    timsp8
    NY
    I never had an issue just spraying it down at the car wash, but I’m not a detailer.
  3. Mar 1, 2021 at 1:22 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    I was thinking of just opening it up and spraying it as well. Not sure if anything needs to be covered...
  4. Mar 1, 2021 at 1:32 PM
    Sean492
    Sean492 New Member
    Winston Salem, NC
    2018 MGM Tundra Sport
    I spray the dirty areas with Engine Gunk Cleaner, let it sit for 5 minutes and then spray it off. I try to avoid heavy water stream and stay away from the wires as much as possible. I never do this process unless its completely cooled off and have never had an issue.
    frichco228 and pvn.beluga[OP] like this.
  5. Mar 1, 2021 at 2:31 PM
    Wallygator
    I throw a couple of buckets of soapy water in there when it's completely cool, then rinse it all off, then dry off a lot of it before starting it up.
    pvn.beluga[OP] likes this.
  6. Mar 1, 2021 at 3:42 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Looks like the both of you guys let the engine cool before spraying it down... not a good idea to spray it while warm?
    Wallygator[QUOTED] likes this.
  7. Mar 1, 2021 at 3:53 PM
    TG705
    TG705 Braaaap
    Tony
    San Jose, CA
    2011 super white Tundra double cab
    King 2.5 coilovers, King 3.0 rear bypasses, Camburg uniball UCAs, RCI skid plates, Camburg front bumper, warn zeon 10s platinum winch, monster hook reaper shackles, Rigid Industries lights, SDHQ sliders, SDHQ A-pillar brackets, SPOD, 17" Method standard wheels, 315/70/17 Cooper STT tires, Morimoto XB LED headlights, Boon dock steel rear bumper, Durobumps front bumpstops, Deaver U748 with MCM shackles
    I sprayed gunk foamy engine cleaner over my entire engine bay while it was completely cool, just covered my fuse box and SPod. let it sit and sprayed it off with a shower nozzle. went for a drive to evaporate all the water. Never had any issues. the gunk cleaner really works great!
    TheBeast likes this.
  8. Mar 1, 2021 at 3:59 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Guys I wouldn't just cut loose with a hose in there. Lots of electronic parts that don't really need water. Now, if you are careful with the hose then it can be used but I don't typically do that. If you have access to compressed air, that's one of the safest ways to blow away dirt. Just agitate it with something like a toothbrush.
    https://www.youtube.com/watch?v=PRSoRkM8GcM&t=604s
  9. Mar 1, 2021 at 4:01 PM
    Tonkatoytaco
    Tonkatoytaco New Member
    Louie
    Maryland
    2017 Platinum XP MGM
    LRO 3/1 Leveling Kit, Dirty Deeds 10" exhaust, Bully Dog Programmer, AFE Super stock Intake with TB Spacer, Custom Rough Country Grill, Andres Devil Horns, Caliraised Fog lights, Morimoto XB Headlights, HRS taillight, Boost Auto tow mirrors, LED interior lights and Reg, light, Trail edition bed compartment, TRD rear sway bar, weathertech floor mats and window visor, Nitto Ridge grappler.
    I have always used a yard sprayer like you would use to spray plants or whatever, I mix 1 part purple bottle super clean degreaser and 2 part water. water down the engine bay, spray the mixture on it, let sit for a few min and spray off. Also do this on my wheel wells. Real dirty areas may need a little scrub to agitate
    jhardy1979 and pvn.beluga[OP] like this.
  10. Mar 2, 2021 at 6:28 AM
    Sean492
    Sean492 New Member
    Winston Salem, NC
    I think the cleaner is able to soak in and break loose the dirt a lot better when the surfaces are cool. The heat can evaporate the cleaner and water you spray to quickly to get the job done.
  11. Mar 2, 2021 at 9:14 AM
    Wallygator
    No. In fact I usually do it in the morning before ever starting the truck so it's completely cold when I do it. An as @FirstGenVol mentioned, I don't directly go fire hose on anything electric.
