Engine cleaning
Discussion in '2.5 Gen Tundras (2014-2021)' started by Duff21TSS, Jul 1, 2024.
  1. Jul 1, 2024 at 4:44 PM
    Duff21TSS
    Duff21TSS [OP] New Member
    Roger
    2021 TSS SR5
    Is it safe to spray the engine with a water hose and cleaner?
  2. Jul 1, 2024 at 4:47 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Yes but not with high pressure. I cover the battery, fuse box and alternator.
    The detailer section will have more....details.
    ZappBrannigan, DZ_ and Terndrerrr like this.
  3. Jul 1, 2024 at 4:55 PM
    RobertD
    Robert
    DFW, Texas
    :rimshot:
  4. Jul 1, 2024 at 5:08 PM
    Saltyhero13
    How I think it went:
    How it actually went:
  5. Jul 1, 2024 at 5:33 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    ZappBrannigan and Saltyhero13 like this.
  6. Jul 1, 2024 at 6:44 PM
    DZ_
    DZ_ New Member
    Frederick Co., MD
    2019 Tundra Crewmax Limited TRD DadWagon
    Thank you for this
  7. Jul 1, 2024 at 6:46 PM
    Saltyhero13
    I'm here for you.
  8. Jul 1, 2024 at 7:00 PM
    Mr Badwrench
    Mr Badwrench New Member
    I use a 2800psi pressure washer with a wide degree tip (30 deg) from about 3 feet away in quick sweeping motions over nearly all engine components. Avoid coil packs and electrical connections. Low volume and medium pressure in fast sweeping movements. The car wash wand is fine. I've done it to hot engines without issue, just don't concentrate the spray.
    Fast sweeping motions.
    koditten and Saltyhero13 like this.
  9. Jul 4, 2024 at 5:45 AM
    Duff21TSS
    Roger
    2021 TSS SR5
    Thanks for the info.
  10. Jul 4, 2024 at 6:08 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Yes. I do it all the time. Do it on a completely cool engine. I use filtered water from the hose and on a low pressure. Spray cleaner. Rinse off with hose. You really have to use some common sense when it comes to cleaning under the hood. If you see electrical, don’t go spraying a high pressure stream right over it. The engine bay is designed to get splashed with water, so connectors are water resistant….not water proof. Just keep that in mind and you will have no issues.
