Engine Break-In
Discussion in '3rd Gen Tundras (2022+)' started by DesertDwellerFeller, Jan 8, 2025.
  1. Jan 8, 2025 at 12:41 PM
    DesertDwellerFeller
    DesertDwellerFeller [OP] New Member
    Coming soon...
    Depends on if I run out of glue and colored paper
    I figure with all the science, testing and new owners it might be interesting to see how everyone's break-in procedure differs.
    I've always done the low RPM for first 1k, with first 350 miles under 50 MPH, then remainder on highway under 75. Then first oil change and analysis before 1500
  2. Jan 8, 2025 at 12:45 PM
    jayhawknavy02
    jayhawknavy02 New Member
    SOCAL
    2017 Tundra 5.7L SR5 Crew Max TRD Off Road 4x4
    Dirty Deeds 10” exhaust TRD Accelerator OTT Tune Sony XAV-9000ES Head Unit AJT Interior Upgrades
    Drive like the manual asks, then oil change at 500 miles.
    If the oil has metal particles, repeat at 1000 miles (should be clear at that point)
    If good, then change at 5,000 and let the dealer do it at 10,000 since its under warranty.
  3. Jan 8, 2025 at 12:50 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Just do what it says in the owners manual for break-in...except for the oil change recommendation. Jayhawk as it right on the oil change intervals.
    Centurion25 likes this.
  4. Jan 8, 2025 at 1:11 PM
    MoJet777
    MoJet777 Shiny side up
    Mo
    Plymouth, MA
    2025 WC Pearl Tundra Platinum
    Same question. Doing a 1600 mile drive starting at about 200 miles on new Tundra. Will it survive until I get there or change oil on the way?
  5. Jan 8, 2025 at 1:24 PM
    frichco228
    Personally, drain and fill only, never a flush. And usually do the drain and fill every 30-50k miles. I do the diffs and xfer case at same time as the trans. All that is drain and fill.
  6. Jan 8, 2025 at 2:19 PM
    jayhawknavy02
    SOCAL
    100%
  7. Jan 8, 2025 at 2:57 PM
    Third-Reef
    Third-Reef New Member
    Gary
    2025 1794 TRD offroad
    I do as the manual says with easy diving for the first 1K miles, keeping the rpm down and varying them. I however add in small bursts of higher load for short periods. There is a lot of talk and evidence that the short period higher load seats the rings better. Combustion pressure forces the rings against cylinder walls and seats them in a slightly different shape than they have under low load. Theory is that you want the rings sealing well under higher load. Breaking in under load is the norm for race engines.
    My truck is running perfectly and the engine has not self destructed, so my method must work. :)
  8. Jan 8, 2025 at 4:11 PM
    SM Tundra
    SM Tundra New Member
    Cody
    2024 Limited Smoked Mesquite Tundra
    Meh, drive the shit out of it and if it breaks it breaks. Word on the street, all 3rd gens will fail so might as well redline it till she blows.
    MaineTundy likes this.
  9. Jan 9, 2025 at 11:58 PM
    dagooaz
    dagooaz New Member
    Dave
    2024 Tundra TRD Off-Road Limited Solar Octane
    I started out light for the first few hundred miles and then slowly ramped up the throttle usage as the miles accumulated. I got to 1K miles and did a few full throttle runs to feel the beast out and then immediately changed the break in oil out.
  10. Jan 10, 2025 at 2:37 AM
    Soupbean77
    Soupbean77 New Member
    2023 Mag Grey Tundra Limited Crewmax 4x4
    If you’re a mechanic, engine builder or machinists, then you’re aware of the importance of proper break in procedures concerning longevity and durability. I’ll typically follow how the manual describes. Not sure if I went even 500 mi before changing out the original oil and filter. As others have stated, properly seating the rings and tempering different metals and alloys that have different rates of expansion and wear is important if you’re looking for long term ownership. Transmission, drivetrain components and brakes will also benefit from proper break in. I drive very few miles with personal vehicles, so change every 5,000 miles or annually, whichever comes first.
  11. Jan 10, 2025 at 5:47 AM
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    24 Limited CM 5.5 Blueprint TRD OR
    5100's, 285/75/18, Air Lift bags, bits and bobs
    My break-in consisted of a 6 hour, 415 mile road trip home from the dealer I got it from. Didn't do anything special other than tried to vary speed by 10 mph or so.
    First oil change at 1K miles. Didn't go full throttle until after that.
    Metro14536 and 75tranzam like this.
  12. Jan 10, 2025 at 6:38 AM
    75tranzam
    75tranzam New Member
    Midlothian, Va
    2024 Midnight Black 1794 Limited Edition #751
    Same for me, drove to Virginia from Illinois where I bought the truck. Tried to not go into a passing gear since it was mostly highway miles.
  13. Jan 10, 2025 at 6:56 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    I hope none of yinz actually drove your trucks off the lot with the breaking oil still in there.
    I drop that oil right at the dealership and refill with Signatures Series "Bearing Savior" oil.
    MooseLang and KNABORES like this.
  14. Jan 10, 2025 at 12:22 PM
    ESalt206
    ESalt206 25 Limited
    CO
    25 Limited Lunar Rock
    UnderCover Flex, mud flaps, Beat Sonic amp, Predator side steps. To come... heritage grille and 20in light bar
    I did the exact same thing from St. Louis back to Denver. Signed papers after the test drive and walk through/inspection and then got in and drove. Varied speed a little, but kept a light throttle and enjoyed the wide open spaces.
  15. Jan 10, 2025 at 12:27 PM
    LightTheBeam
    LightTheBeam New Member
    Sacramento, CA
    2024 Tundra Limited
    Bone stock (for now)
    I just drove it normally and changed the oil at 5K with about 50/50 highway/surface streets. Unless you're towing or taking it on the autobahn I think it was enough.
    Tundrastruck91 and Centurion25 like this.
