Engine and TC OFF lights
Discussion in '2nd Gen Tundras (2007-2013)' started by Teambrown7, Jun 20, 2024.
  1. Jun 20, 2024 at 8:10 AM
    Teambrown7
    Teambrown7 [OP] New Member
    Martin
    2012 Tundra
    So I’ve been having an issue with the CEI and TC Off lights being on and my truck being in limp mode. I’ve done some research and found that the Hewitt-Tech SAIS kit should fix that. So I ordered it, installed it and had the battery disconnected throughout the process and when I reconnected the battery and started the truck the lights came back in and it’s still in limo mode…
    Is there a certain amount of time that I should drive/let the truck run to see if it will reset or is it supposed to be immediate??? It’s a 2012 with the 4.0.
    Could definitely use some advice on this….
  2. Jun 20, 2024 at 11:06 AM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    Find out what active DTCs (trouble codes) you have. Until then, you're just guessing.
    Teambrown7[OP] and FrenchToasty like this.
  3. Jun 20, 2024 at 11:30 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    If you don't have a code reader, take it to Oreilly's or autozone and have them run diagnostic tests. They wont clear the codes, but gives you a better idea.
    Teambrown7[OP] likes this.
