Engine Additives
Discussion in 'General Tundra Discussion' started by TundraTss, Nov 24, 2017.
  1. Nov 24, 2017 at 10:17 AM
    TundraTss
    TundraTss [OP] The Mistress
    Brandon
    2019 TRD SR5
    Everything. Literally.
    So I’m wondering about engine additives for 3rg gen Tundras.
    Nothing crazy, just products that help lubricate, protect from breakdown, gas system cleaners, etc.
    In my wife’s subie, we were told by a Subaru mechanic that their engines don’t really get along with aftermarket additives, I’m just wondering if anybody has any info on this topic when it comes to the Tundys.
  2. Nov 24, 2017 at 8:37 PM
    muisejt
    muisejt New Member
    2017 Sunset Bronze 1794 Edition 4x4
    Auburn LSD, TRD rear sway bar, LED interior lights, Weathertech floormats, Fumoto valve
    all you need is to use top tier gas and change your oil every 3000 miles
    Tony v, Randy Morton and geno0506 like this.
  3. Nov 24, 2017 at 10:15 PM
    Nothing in my Tündra
    Randy Morton likes this.
  4. Nov 25, 2017 at 4:01 AM
    Tundraplatinum
    Tundraplatinum New Member
    2016 Platinum CM
    be sure to use full synthetic oil, don't add anything to it
  5. Nov 25, 2017 at 4:18 AM
    chphilo
    chphilo Tundra addict
    Western PA
    I use Mobil 1 full synthetic 0W-20 and don't do anything to that, except to change it regularly. I have in the past put stuff to get water out of gas right before winter hits full force. I also put silicone spray all around the weather stripping on my door to keep the door from freezing. I see the benefit of silicone, but I see no benefit/difference from gas additives.
    TundraTss[OP] likes this.
  6. Nov 25, 2017 at 4:57 AM
    tye
    tye New Member
    tye
    2016 TRD Pro DC
    Diamondback cover, flowmaster exhaust, n-fab sliders
    Every so often I add Seafoam to my gas to take care of the injectors and deal.with any water in the gas. Been doing this with my 2002 for 15 years.
  7. Nov 25, 2017 at 6:12 AM
    Slayer
    Slayer Member
    Slayer
    Agree with others..
    top tier gas, oil changes per Toyota's schedule, seafoam in the tank couple times a year (great stuff)
  8. Jan 2, 2019 at 7:24 AM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    Do you just use half a can the fill it up?
  9. Jan 2, 2019 at 7:27 AM
    BIGUGLY
    Paul
    2018 Limited
    Seafoam or Lucas upper cylinder. Just a few times a year. After tearing into a motor that used sea foam and Lucas,I was amazed at how clean it was.
    UNTMatt likes this.
