Engaging 4wd regularly... I have never done this
Discussion in '2.5 Gen Tundras (2014-2021)' started by tundrathr0w, Oct 26, 2019.
  1. Oct 26, 2019 at 2:21 PM
    tundrathr0w
    tundrathr0w [OP] New Member
    2018 Silver Sky Metallic Tundra CrewMax 4x4 5.7L
    I just realized my owner's manual says I have to be engaging my 4wd for 10 miles every month to keep things lubricated.
    I have never done this. 2018 Tundra, I've used 4wd on and off during the winter months (Dec, Jan, Feb), so the last time I turned on 4wd this year was 8 months ago.
    What kind of impact does failing to exercise the 4wd have on my truck?
  2. Oct 26, 2019 at 2:24 PM
    art64
    art64 New Member
    Mechanism can get stuck in engage position or it may not engage at all.
  3. Oct 26, 2019 at 2:25 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Probably prevents the shift solenoid/shift motor from locking up. Had this happen to my previous truck when I moved to CA and stopped using 4wd. It dropped into 4wd but wouldn’t come back out
  4. Oct 26, 2019 at 2:29 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    At lease you use it in winter, I never see snow. I try to use it and I forgot about it in the parking lot. can't turn with the 4wd engage.
    hope I didn't mass things up.
  5. Oct 26, 2019 at 2:48 PM
    tundrathr0w
    So if I can get into 4WD and back out again, does that mean I haven't damaged anything due to lack of use of 4WD?
  6. Oct 26, 2019 at 3:04 PM
    tundrathr0w
    Why not? Are you not concerned about the mechanism locking up from lack of use?
  7. Oct 26, 2019 at 3:38 PM
    Blue Thunder
    Washington
    Ten miles? I’ll go run a few circles and figure eights in a gravel parking lot if/when I find one, but running for 10 miles is nuts. Once a month is nuts too.
  8. Oct 26, 2019 at 3:45 PM
    timsp8
    NY
    I haven’t been in 4wd since last winter. Same with other trucks I’ve had. Never had an issue.
  9. Oct 26, 2019 at 4:15 PM
    I use it when I remember, like today. 75* and I had a straight road for a few miles.
    Tomorrow? Could be up to 8” of snow through Monday lol.
    Black Wolf, MS22, teamtlr and 4 others like this.
  10. Oct 26, 2019 at 5:11 PM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    I'm probably the exception to the rule. I do it monthly, although I don't always hit the mileage. The last 5 miles or so of my daily ride home is a straight, 35mph road so it's easy to put it in 4hi and cruise. Shifts in and out like butter.
  11. Oct 26, 2019 at 5:27 PM
    15whtrd
    15whtrd Mr. Blonde
    I definitely don’t do 10 miles a month, but I do try to do it every so often for a few miles on the street piece of road on my way to work. I think they suggest 10 miles so that you heat up the fluid enough to get it properly lubricated, maybe even so that you burn off any moisture that may have built up inside. But I am guessing LOL
  12. Oct 26, 2019 at 5:34 PM
    Haggis777
    Haggis777 I.L.J.C.M.L.
    SW Michigan
    2015 Silver SR5 TRD Tundra Canadian Model
    LEDs interior & exterior, stubby antenna, Bak-Flip cover, 285's, AGM battery, block heater, Pine tree air freshener
    We live on a straight stretch of country road about 3 miles long. Couple times a month I will kick it into 4WD on the way to work and then on the way home on that section.
    Helps keep that transfer case lubricated without putting any stress on it by going straight.
    Rebel Tundra Man and 15whtrd like this.
  13. Oct 26, 2019 at 5:37 PM
    15whtrd
    15whtrd Mr. Blonde
    Your avatar always creeps me the F out!:rofl:
  14. Oct 26, 2019 at 5:52 PM
    biebs96
    PA
    Since I moved to this house, I have a 2 mile stretch (40 mph) of straight road on my daily commute. I engage it every Friday on the way to work for that section.
    I did so on my 2nd gen for the last 5 years of owning it. And I’ve done so for the first 6 months of owning my 3rd gen.
    It’s just nice to hear everything clicking and popping and clanking into place and then again out of place. Simple piece of mind. Plus I’d rather have my 4wd fixed in July, then in February when I actually need it.
    GODZILLA, T-Rex266 and 15whtrd like this.
  15. Oct 27, 2019 at 4:38 AM
    mnm
    mnm Old Guy...
    Mark
    Smithfield, VA
    2008 Tundra Limited 4x4 DC
    I drive a 3 mile straight paved road every day to work and I engage 4wd HI 3 to 4 times a month. I might do 4wd LO every 6 months or so for less than 100 feet just to make sure it still works.
    duece292 likes this.
  16. Oct 27, 2019 at 4:54 AM
    TOYOTRD8
    TOYOTRD8 New Member
    Utah
    2017 TUNDRA SR5 TRD OFF-ROAD
    TRD Pro Grilled, Color match bumper end caps, OEM LED headlights, MX4 Bed cover, GoRhino RB20,TRS LED Fog Lights, Camburg leveling kits, SR8 wheels, STT Pro tires 295/70/18 and heritage decal.
    Lol. I hope he’s only used it during Halloween month. :anonymous:
    15whtrd[QUOTED] likes this.
  17. Oct 27, 2019 at 6:17 AM
    GravityGear
    GravityGear Parking Lot Prerunner
    Aurora, CO
    2014 Black DC TSS Off Road 4x4 5.7
    Transfer Flow tank, Pinstripe Suit
    I'm on the dirt typically 2 weekends a month so I don't worry about it anymore. BUT, before I decided to start regularly froadin' I would put it in 4wd during my commute on a stretch of straight road.
  18. Oct 27, 2019 at 7:15 AM
    Blue Thunder
    Washington
    I need a better commute. If I’m not turning right or left, I’m stuck at at stoplight waiting to turn right or left. Only time I’m going straight is on the highway and then it’s a game of Jack-Wagon Driver Dodgeball.
    Hmm...sounds like I need to plan a monthly road trip...
    WFD473, Cpl_Punishment and duece292 like this.
  19. Oct 27, 2019 at 7:22 AM
    2chains
    2chains New Member
    Southern Ablerta
    Just wondering if folks are engaging 4wd on pavement?
  20. Oct 27, 2019 at 7:29 AM
    PA452
    PA452 New Member
    2021 Tundra SR5 CM TRD O/R
    I find enough reasons to engage 4WD now and then for an actual purpose between winters. But yeah, it's usually only briefly.
    Ten miles per month always seemed crazy to me.
  21. Oct 27, 2019 at 7:31 AM
    PA452
    PA452 New Member
    I wouldn't if you don't have to, even if you think you're driving straight.
    TundraDude18 likes this.
  22. Oct 27, 2019 at 7:32 AM
    duece292
    Greg
    Green Bay, WI
    I do. I think several others here do as well. But... we're all on straight roads, no sharp turns and lower speeds. I stay under 40mph when doing it.
    NewImprovedRon and Black Wolf like this.
  23. Oct 27, 2019 at 7:35 AM
    Professional Hand Model
    Hand Protectors
    Yes, but just on straight runs. At stop lights, I’ll engage the 4LO every so often (just engage but not drive) so the actuator gets the exercise to keep the cob webs off.
    NewImprovedRon likes this.
  24. Oct 27, 2019 at 7:35 AM
    Genuine Cooling Systems
    Genuine Cooling Systems New Member Vendor
    Engaging on dirt can be just as bad as using it on pavement. Your not getting slippage on packed dirt.
  25. Oct 27, 2019 at 7:37 AM
    PA452
    PA452 New Member
    Agreed.
  26. Oct 27, 2019 at 8:40 AM
    DividedSky
    DividedSky New Member
    Jeff
    '18 Crewmax - ADS Mid Travel
    ADS 2.5's (rear bypass) U748 Leaf Springs
    It’s perfectly fine to engage 4WD on pavement when driving in a straight line. It’s turning that might cause premature wear.
  27. Oct 27, 2019 at 2:01 PM
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    I have a fairly traffic-ridden stretch of I 205 on my daily commute. I set the cruise at 55 and don’t change lanes. Usually keep it engaged 3 or 4 miles and turn it off before I exit for work and hit the surface streets.
    Black Wolf likes this.
  28. Oct 27, 2019 at 2:47 PM
    MGM2018OR
    MGM2018OR New Member
    Craig
    2018 MGM OR dbl cab ( gone but not forgotten )
    What? Sure you are and it’s not going to hurt anything so long as your not turning the tires lock to lock and mashing the gas pedal.
    Magnetic15, 15whtrd and Black Wolf like this.
  29. Oct 27, 2019 at 3:06 PM
    LGTruckWesternSlope
    LGTruckWesternSlope New Member
    2019 Super White Tundra Limited Double Cab TRD Off-Road 4x4
    Does the auto LSD when engaged have any benefit to 4WD being exercised monthly and worrying about pavement or not?
  30. Oct 27, 2019 at 3:13 PM
    15whtrd
    15whtrd Mr. Blonde
    No, it’s not a real LSD. Just activated by the brakes squeezing the spinning wheel.
