Emergency braking….
Discussion in '3rd Gen Tundras (2022+)' started by Pstan, Feb 5, 2024.
  1. Feb 5, 2024 at 5:08 AM
    Pstan
    Pstan [OP] New Member
    With my previous vehicles I would always occasionally test out the emergency brake. I know the park brake can be set to auto engage, however I’ve chosen to have that mode off. At a low speed I engaged the switch for a half second on my 2023 SR5 and it immediately locked up the brakes. Don’t see anything in the manual about using this brake while moving.
    is there any way to use “emergency” braking without locking up the wheels?
  2. Feb 5, 2024 at 5:18 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    I think that is now referred to the “parking brake” to be used when stopped only. In the past we referred to it as the emergency brake. I think there is very little brake material on the brake shoes, it’s just to take all the tension off the transmission when parked.
    Someone correct me if I’m wrong.
  3. Feb 5, 2024 at 6:20 AM
    teab
    teab 2023 Platinum w/ PRO bits
    Ty
    Denver
    2023 Platinum MGM 6.5
    TRD Pro Wheels, Go Rhino D6, Airlift bags/compressor, Talons Alum Cat Shield, Cheap-o Amazon Mud Flaps, Fastop Tonneau/Topper, Rear TRD Pro Shocks
    Yeah you're confusing the emergency breaking safety system with a parking brake. Those two things are not the same. Highly suggest you read your owners manual on the emergency braking. Do not use your parking brake while moving unless you have no other choice.
  4. Feb 5, 2024 at 6:58 AM
    doublethebass
    doublethebass New Member
    Minneapolis
    2017 Tacoma TRD Pro 6MT
    will it even try to engage?
  5. Feb 5, 2024 at 7:00 AM
    DRP
    DRP Old Member
    Dave
    Yes.
    teab and doublethebass[QUOTED] like this.
  6. Feb 5, 2024 at 2:37 PM
    Pstan
    I guess an independent brake application system for emergency use by the driver is a thing of the past, for new Tundras. There is nothing I could find in the tundra 2023 manual that suggests, recommends, or instructs you to use emergency braking. I think that is an omission. Maybe others don’t. As teab has pointed out, there is emergency braking, but the system is automatic, no input from the driver required.
    And yes you can engage the park brake while moving, I tried, and that's what prompted my inquiry.
    Good info.
    doublethebass likes this.
  7. Feb 5, 2024 at 2:45 PM
    doublethebass
    Minneapolis
    what happened when you tried it? Did the back wheels lock up?
  8. Feb 5, 2024 at 3:56 PM
    DRP
    DRP Old Member
    Dave
    There is a very short comment in the manual. Section 4-2 (pages 212 & 212 in my manual) :
    Pull and hold the parking brake switch if an emergency occurs and it is necessary to operate the parking brake while driving.
    Seems like they could have added more info about what to expect if you do that. The wife's 2016 CX5 is the same way. Definitely takes getting used to not having an old fashioned e-brake. I've been meaning to test it like you did so thanks for confirming what I thought would happen.
    Mattedfred and doublethebass like this.
  9. Feb 6, 2024 at 5:04 PM
    Pstan
    Good find DRP. I missed that when I scoured through the 600+ page manual
    Doublethebass, I’m note sure what wheels locked up. The vehicle just stopped suddenly, from a very low speed.
  10. Feb 6, 2024 at 5:21 PM
    DRP
    DRP Old Member
    Dave
    Yeah, that manual is something else.
    Mattedfred likes this.
