Eliminating TPMS light permanently
Discussion in 'Wheels & Tires' started by Lias, May 15, 2019.
  1. May 15, 2019 at 10:24 AM
    Lias
    Lias [OP] New Member
    Lias
    how to eliminate the tire sensor light forever, I'm not interested I have several tires and I do not want the light , 2017
    Mountun Goat likes this.
  2. May 15, 2019 at 10:33 AM
    Makoy339
    Makoy339 Simplicity = Reliability !!!
    Super White TRD
    TRD parts
    ColoradoTJ, Sas and jewsNbrews like this.
  3. May 15, 2019 at 12:00 PM
    Lias
    Lias
    Thanks for the help
  4. May 15, 2019 at 3:03 PM
    Lias
    Lias
    already perfect thanks
  5. May 15, 2019 at 4:19 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    If you dont wanna cut wires you can make a small tube out of 4" abs pipe, a cap, and a threaded clean out piece. Then drill a hole and thread a tire valve on one end, lastly, put your tpms sensors inside the pipe and pump it up to 50 psi, then just toss the tube under your seat or attach it under the hood or somewhere on the frame.
  6. May 20, 2019 at 3:36 PM
    Waterboyz
    Waterboyz New Member
    Fredericksburg VA
    2006 Silver Tundra X-SP Double Cab 2WD 18" Wheels
    Very interesting......
    Pudge[QUOTED] likes this.
  7. May 20, 2019 at 4:16 PM
    koditten
    Kirk
    Midland of the Mitten
    I forget I did this mod 5 years ago. I forget I even have TPMS.
    Do I miss it?
    Not one effing bit.
  8. May 20, 2019 at 6:23 PM
    I may do the PVC mod for my Lexus. I hate the TPMS, if discount tire will let me.
    Pudge likes this.
  9. May 20, 2019 at 9:00 PM
    papasmurf
    papasmurf Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    @KevinK @osidepunker interesting idea....
  10. May 21, 2019 at 4:58 AM
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    Seems a lot more complicated than a wire mod...
    KISS>KIS
    papasmurf[QUOTED] likes this.
  11. May 21, 2019 at 6:06 AM
    koditten
    Kirk
    This is easy, but may not be liked by border patrol. Random search and you have something that looks like a pipe bomb? Not gonna make some pro's happy.
    Sas likes this.
  12. May 21, 2019 at 6:27 AM
    GravityGear
    GravityGear Parking Lot Prerunner
    Aurora, CO
    2014 Black DC TSS Off Road 4x4 5.7
    Transfer Flow tank, Pinstripe Suit
    I did the "pipe bomb" in my old Subaru. I had a street and track set of wheel and tire combos that would not fit the sensors. The "pipe bomb" will lose air, but a quick top off with a bike pump and off goes the light. Put some cotton or fiber fill in there so the sensors don't make noise while you're driving.
    ColoradoTJ likes this.
  13. May 21, 2019 at 6:43 AM
    Coupe
    Coupe New Member
    James
    Houston, Texas
    2008 Toyota X-Runner
    TRD S/C, headers, APR X1, T56 Magnum 6 spd, NST pullies, Stptech Big Brake Kit, dropped, leather
    I just put a piece of electrical tape over the light.
    papasmurf and NewImprovedRon like this.
  14. May 21, 2019 at 2:26 PM
    KevinK
    KevinK SGU - High Speed Overlander
    Back in Arizona. Again.
    SGU - Speed Glampers Uberfahrt
    Tundras to Sedona
    Or ignore the light like I have for 4 years. Eventually that fucker will burn out.
    Newm and 15Yota like this.
  15. May 21, 2019 at 2:54 PM
    DividedSky
    DividedSky New Member
    Jeff
    '18 Crewmax - ADS Mid Travel
    ADS 2.5's (rear bypass) U748 Leaf Springs
    Agreed!
    I use two sets of wheels (stock/DD set and my MT off-road set) and I have the TPMS light on every time my off-road set is mounted. The little TPMS light barely registers when I look down though. It really isn't that big or bright.
    If it really bugs you, Put some kind of sticker over the TPMS light so you don't see it. Little piece of electrical tape, scratch n sniff sticker, wadded up chewing gum...
  16. May 21, 2019 at 2:59 PM
    Cuzican
    Cuzican New Member
    Louisiana
    2017 Black Platinum Crewmax Tundra
    8" Lift, 22x10 Fuel Forged FF19, 37x13.50r22 Trail Grapplers, Amp Research steps, Spyder black smoked headlights with 35w HID's, all interior lights LED, Undercover tonneau.
    In the past, I just evenly drilled 4 extra valve stem holes in the spare and installed all 4 sensors in the spare. Benefit was they were out of the way, didn't lose air as fast as the "pipe bomb" method, and you knew when your spare needed a top off.
  17. May 21, 2019 at 4:04 PM
    koditten
    Kirk
    Holy shit! This has got to be the most original idea I've ever heard!
    I'm gonna stop right here. Anything else I type is going to get me banned.
    osidepunker and Pudge like this.
