Electrical problems
Discussion in '2.5 Gen Tundras (2014-2021)' started by hansen1996, Nov 5, 2018.
  1. Nov 5, 2018 at 8:02 PM
    hansen1996
    hansen1996 [OP] New Member
    So I have the stock head lights and taillights in my 2014 toyota tundra crew cab. My front 2 head lights low beam works but when I go to highbeam, the right one shuts off. My tailights running lights don't work but brake lights do.
    I've checked every fuse twice
  2. Nov 5, 2018 at 8:32 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Welcome. You don't, by chance, live in a rural area where rodents abound?
  3. Nov 5, 2018 at 9:08 PM
    hansen1996
  4. Nov 5, 2018 at 11:38 PM
    TTund16
    TTund16 New Member
    Did you buy the car new?
    did you replace any lights with LED lights?
  5. Nov 5, 2018 at 11:47 PM
    TTund16
    TTund16 New Member
    You see any water in any of the lights? Also the brake light / cargo light up high?
    Oh wait, i forgot you own a Tundra not Ford :D
  6. Nov 6, 2018 at 6:15 AM
    hansen1996
    i dont see any water in them and yes brake light works fine
  7. Nov 6, 2018 at 6:53 AM
    hansen1996
    so ive checked the fuse on the tailights it was burnt out i replaced it and it burnt out agian right away so theres gotta be a short somewhere
  8. Nov 6, 2018 at 10:18 PM
    TTund16
    TTund16 New Member
    How did you miss? :DL
    any moisture or did you replace any lights with LED?
  9. Nov 7, 2018 at 6:05 AM
    hansen1996
    there was some water in the tail lights when i took them out
  10. Nov 7, 2018 at 12:41 PM
    TTund16
    TTund16 New Member
    Look for cracks or bad seal.
    I had a tiniest hole in my headlight ... very old car & very time consuming to replace the headlight. you could barely see the hole ... I covered it with super glue over 10 years ago and still holding up.
