Electrical Problem
Discussion in '2nd Gen Tundras (2007-2013)' started by esm1949, Jul 27, 2019.
  1. Jul 27, 2019 at 11:38 AM
    esm1949
    esm1949 [OP] New Member
    Ed
    2008 basic extra crew cab
    I an having a problem shifting of park. Have to step on the brake multiple times and sometimes I have to re start the truck several times and step on the brake multiple times again Any one know how to fix this problem? Thanks ESM1949
  2. Jul 27, 2019 at 11:45 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    The first thing I’d be looking at is if the brake lights are still working correctly when you’re stepping on the brake pedal but not able to shift out of park.
    If no brake lights when you can’t shift, then my main suspect would be the stop light switch on the brake pedal.
    If you do have working brake lights, then the park lock solenoid in the shifter would be the suspect.
    Is it a column shifter, or a console shifter? Spill any sugary drinks around the shifter lately?
    AZTundra likes this.
  3. Jul 27, 2019 at 12:40 PM
    AZTundra
    Paul
    Phoenix, AZ
    ^^ Above is 100% spot on. I just went through this on my wife's Armada. Ended up being the brake switch for us (about $48 from Nissan and 5 mins to install). Problem solved.
    NewImprovedRon likes this.
