Electrical plugs
Discussion in '2.5 Gen Tundras (2014-2021)' started by Toyotaguy99, Apr 18, 2024.
  1. Apr 18, 2024 at 6:05 PM
    Toyotaguy99
    Toyotaguy99 [OP] New Member
    Old
    2021 trail
    Rear bumber
    After adding a metal bumper I can’t find any waterproof plug to seal my BSM connectors. I wrap black electrical tape so water won’t get into it. Any insights on where I can buy waterproof cancellation plugs? I know wrapping with black electrical tape is just temporary/troubleshooting.
  2. Apr 19, 2024 at 6:18 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Could you just use that liquid electrical tape or even Plastidip would help...at least, that's what I'd consider first
    Toyotaguy99[OP] likes this.
  3. Apr 19, 2024 at 6:36 AM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    So, the BSM connectors are now disconnected/ unused? If so, you could use adhesive lined heat shrink. Cut a long enough piece to fit over the connector and leave another inch or two in length. Heat shrink it, squeeze the extra length together to seal it, and fold it over. Then, cut another small piece of heat shrink, slide it over the first piece with the folded over length, and shrink it. This piece prevents the first piece from unfolding and provides another layer of protection from moisture.
    https://www.amazon.com/gp/product/B084GDLSCK?ie=UTF8
  4. Apr 19, 2024 at 6:55 AM
    TundraClayDigger
    TundraClayDigger New Member
    2018 Crewmax Limited 4X4
    As Mr. Bluecrush said, heat shrink is the stuff. That is what I use on my boat's electrical connections. It hasn't let me down yet.
  5. Apr 19, 2024 at 7:03 AM
    Toyotaguy99
    Old
    2021 trail
    Rear bumber
    Thank you all for the replies. I will put it to use.
