Electrical issue
Discussion in '2nd Gen Tundras (2007-2013)' started by GeauxStros, Mar 2, 2023.
  1. Mar 2, 2023 at 11:04 AM
    GeauxStros
    GeauxStros [OP] New Member
    2013 Black Texas Edition Tundra
    Hi all.
    I did something stupid. I purchased a bull bar with LED lights. I hooked everything up and tested the lights without issue.
    HOWEVER, when I tried to crank the truck, nothing happens. I don't get a chime when I put the key in the ignition, no interior lights, etc...
    So, I looked again at my connections and realized that I hooked the relay from the LED bar to the same screw as the negative battery connection to the body.
    I assumed the main fuse was blown, so I ordered a new one and have already replaced it. That did not, however, solve the problem.
    What else could be causing the problem? Help!
    (not the battery)
