Electrical gremlin
Discussion in '2.5 Gen Tundras (2014-2021)' started by PRSmith5, Nov 30, 2021.
  1. Nov 30, 2021 at 10:27 AM
    PRSmith5
    PRSmith5 [OP] New Member
    Peter
    '19 Tundra Crew-Max Limited
    Out of nowhere, I have three things that have stopped working. 1) both key fobs (yes, I replaced one battery to see if that was it, still no response) 2) the power lock button, no response, 3) the interior lights do not light up when I open the door. The rocker switch is in the right position - "Door". If I insert the key and turn to ACC, the interior lights will illuminate. Ideas?
  2. Nov 30, 2021 at 10:30 AM
    bwh
    bwh New Member
    Car battery is almost dead.
    biebs96 and 1UP like this.
  3. Nov 30, 2021 at 10:51 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Bad battery probably or could be rodent damage. My guess is battery, the factory batteries often only last 2-3 years before having issues, especially in very hot or cold climates.
  4. Nov 30, 2021 at 12:05 PM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    Did you recently replace any of the bulbs in your interior with led’s by chance?
    frichco228 likes this.
  5. Dec 3, 2021 at 3:42 PM
    PRSmith5
    Peter
    Truck fires right up. No indication of a weak battery in any way. I have not changed any bulbs,
  6. Dec 3, 2021 at 3:42 PM
    PRSmith5
    Peter
    I did a thorough inspection of the engine bay....no sign, at all, of rodent activity.
  7. Dec 3, 2021 at 4:21 PM
    ZeRussian
    ZeRussian New Member
    ‘11 CrewMax
    Check the fuses?
  8. Dec 3, 2021 at 4:34 PM
    PRSmith5
    Peter
    I spent the better part of an hour under the dash checking/changing fuses. Never found a bad one. No change. Ugh.
  9. Dec 3, 2021 at 4:39 PM
    biebs96
    PA
    I vote battery on its way out. My truck acted like it was about to either transform or explode when my battery started to go slightly bad.
  10. Dec 3, 2021 at 4:51 PM
    2mchfun
    Add jumper battery and see what happens??
