electrical gremlin? odd door lock behaviour.
Discussion in '2nd Gen Tundras (2007-2013)' started by apwisher, Dec 12, 2022.
  1. Dec 12, 2022 at 11:57 AM
    apwisher
    apwisher [OP] New Member
    Everett, WA
    2007 CM SR5/TRD 4x4 White
    canopy, TRD Sway, audio
    a few weeks ago I disconnected by battery to install new terminals. since then ( I think, or around that time) i have been having a new/odd behaviour. when I lock the doors via the fob the doors lock, but i no longer get a beep. also, if i hit it twice I get no beep and the headlights do not turn off like they did before. When I use the fob to unlock the truck all seems normal, and I get the beep. If the truck gets locked with the fob and i let it sit for 15 seconds the headlights go out like normal.
    my questions are thus: Are the lock and unlock settings in the ECU independent? Can you have beep on unlock and not lock? I suspect maybe something got scrambled when i reset the battery. if they are not independent, any idea what would cause the change in lock behaviour?
    thanks.
  2. Dec 12, 2022 at 12:04 PM
    apwisher
    Everett, WA
    did a bit more digging and see that lock/unlock settings are seperate. weird
    unfortunately i don't have a working TS pc anymore.
  3. Dec 12, 2022 at 6:45 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    Just shooting from the hip here but I think those are all settings that can be changed or modified with Techstream. Maybe your truck forgot some pervious setttings
  4. Dec 12, 2022 at 6:48 PM
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
    If you are ever down south in the Vancouver/Portland area hit up @RainMan_PNW last I heard he has a working techstream PC
  5. Dec 12, 2022 at 7:11 PM
    Musicmasterd12
    Musicmasterd12 New Member
    Southern Louisiana
    2011 4.6 Silver Sky Metallic DC
    I think those were options to adjust when I changed some stuff with my Carista. Maybe checkout getting that if you can’t get Techstream or dealer to set them. I think it was like $50 for it
  6. Dec 12, 2022 at 7:41 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Those settings are in Techstream, but shouldn’t reset from pulling the battery.
    Either dealer can do it, or Carista, or a $60-80 cable from scamazon with bootleg TS. Or, as Brandon said, if you’re ever down this way.
  7. Dec 13, 2022 at 7:34 AM
    apwisher
    Everett, WA
    ok, I dig out my TS cable and see if I can find a copy to use for Win10. Last time I used it it required Win98 and it was a pita. still weird that it zapped some of my settings. thanks folks.
