Electrical failure
Discussion in 'New Member Introductions' started by Glen, Aug 29, 2021.
  1. Aug 29, 2021 at 11:08 AM
    Glen
    Glen [OP] New Member
    Glen
    Dark grey tundra
    New battery 1 month sgo
    New to site. Have a 2011 Toyota Tundra. Twice, while driving, truck has shut down. Once on a on ramp and second while turning around. First time power returned after 30 minutes. Had it towed and nothing was found wrong. New battery placed just for safety. Happened again but being towed and not starting. Any suggestions as to the problem?
    YardBird likes this.
  2. Aug 29, 2021 at 11:10 AM
    14CRWMX
    14CRWMX New Member
    Tampa Bay
    2014 SR5
    Can be lose ground wire somewhere
  3. Aug 29, 2021 at 1:33 PM
    Glen
    Glen
    Dark grey tundra
    Tow truck arrived 2 hours later. As he was loading it the emergency lights came on and it started again. Definitely an electrical issue. Just don’t know where
  4. Aug 29, 2021 at 1:36 PM
    Dr Doobie
    Dr Doobie Growing member
    Talkeetna,Alaska
    '07 RCSB 5.7 SC'd 4x4 SSM
    Time for the wiggle test
    SnowyTundra likes this.
  5. Aug 29, 2021 at 3:41 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  6. Aug 29, 2021 at 3:59 PM
    Gravy
    Gravy Cat herder, ASCM #π
    Yucaipa, California
    2008 White DC 4x4, Limited TRD
    OME Nitrocharger/2612 (front), Bilstein 5100s (rear). Vanguard roll bar modified (by me) to fit over Patriot Stealth retractable tonneau. Aftermarket halo headlights with HID, various LED bulb replacements. 17" Fuel Blitz wheels with some 33" Nitto terra grapplers. Hoodscoop, nfab nerfbars, Bushwacker flares. No-name aftermarket grille, led fender extensions. Black Horse bambi-basher. Various offroad lights.
    Throw up a post in new member section, with some pics. Like they said above, check your grounds. Wiggle test the posts, fuse/relay boxes etc...
    Welcome from SoCal
  7. Aug 29, 2021 at 4:20 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Sounds like a bad ground. My brand new GMC used to do this on the regular and it turned out that the negative battery cable was rotting from the inside out.
  8. Aug 29, 2021 at 4:44 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Battery terminal is probably loose..... a dying battery and a loose terminal would have my truck dying anywhere and everywhere...
  9. Aug 29, 2021 at 5:31 PM
    Welcome from NY.
    Like said above probably a bad ground.
  10. Aug 30, 2021 at 4:58 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! That's a tough one. Bad grounds can be just about anywhere.
  11. Aug 30, 2021 at 7:43 AM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada
  12. Aug 30, 2021 at 9:48 AM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    They sure can but a complete loss of power to everything is going to be more specific.
  13. Aug 30, 2021 at 11:28 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    True enough. I was catching up with the site after a couple of days and responded quickly, but you're right about that.
    ZappBrannigan[QUOTED] likes this.
  14. Aug 31, 2021 at 2:59 AM
