Electric power washer recommendations?
Discussion in 'Detailing' started by gdiep, Mar 26, 2019.
  1. Mar 26, 2019 at 1:53 PM
    gdiep
    gdiep [OP] I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    Okay guys, I need to buy an electric power washer to wash the cars and some light cleaning around the house (concrete patio, siding, etc). I don't need a professional grade machine, and I don't need a gas machine either.
    Looking for reasonably priced electric pressure washer that also can be used with a foam cannon. Feel free to recommend a foam cannon as well.
    Thanks in advance.
    War Machine likes this.
  2. Mar 26, 2019 at 1:57 PM
    War Machine
    War Machine SSEM # 5 3MW
    This is the one I have. Not the cheapest, but I’m very happy with it.
    https://www.lowes.com/pd/Greenworks...old-Water-Electric-Pressure-Washer/1000731280
    For a foam cannon, I use a cheap one from Amazon. I’ve tried others, and see no point in spending a lot of money on them. I’ve had it a couple of years and have used it a ton. No issues.
    MATCC Adjustable Foam Cannon 1 Liter Bottle Snow Foam Lance With 1/4" Quick Connector Foam Blaster for Pressure Washer Gun https://www.amazon.com/dp/B01CE78VO8/ref=cm_sw_r_cp_tai_MiPMCb5XAQXEG
    gdiep[OP], DaBoro54 and ColoradoTJ like this.
  3. Mar 26, 2019 at 1:57 PM
    BIGUGLY
    Paul
    2018 Limited
    Have used a sun Joe. Just get the most gallons per minute. It has worked pretty good, just wish it had a little bit more pressure. It works well with a foam cannon.
  4. Mar 26, 2019 at 2:20 PM
    jtwags
    jtwags Concrete jungle
    League City, TX
    2018 Tundra CM
    Undercover Elite LX, Xact Contour
    gdiep[OP] and ColoradoTJ like this.
  5. Mar 26, 2019 at 4:15 PM
    gdiep
    Syracuse, New York
    @BIGUGLY and @jtwags -
    Do the Sun Joe ones have the 1/4” quick connect?
    @War Machine -
    I think the green works one has 1/4” quick connects and m22 fittings right?
    Thanks guys.
  6. Mar 26, 2019 at 7:25 PM
    BIGUGLY
    Paul
    2018 Limited
    I believe it's the quick connect. My foam gun snaps right on to the wand
  7. Mar 27, 2019 at 4:47 AM
    briarpatch
    briarpatch New Member
    Lots of options for an electric p/w out there. A lot depends on your budget and what you consider 'reasonably priced'. I have a SunJoe SPX3000 and like it. It's rated at 2030 psi/1.76 gpm, but I can tell you that those specs are inflated. When it comes to using a foam cannon, gpm is more important than the psi. I have a cheap 20.00 foam cannon, and it does work pretty well, but I did invest in an MTM PF22, and it absolutely is better...how much better is subjective. Both foam cannons are fitted with the smaller (1.1mm) orifice, as opposed to the standard (1.25mm) orifice they come with. I use the cheap foam cannon for pre-wash foaming, and the PF22 for the wash process.
    You can go all the way up to a Kranzle p/w, but then your out of my reasonable price range (over 800.00). AR Blue Clean has a professional series that come in around the 600.00 mark, and will likely be the way I'll go if I ever go from doing detailing as a side gig to something more substantial.
  8. Mar 27, 2019 at 4:58 AM
    2010bigdog
    2010bigdog New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    is this the one you use for the foam cannon too ?
    War Machine[QUOTED] likes this.
  9. Mar 27, 2019 at 5:07 AM
    War Machine
    Mine didn’t come with quick connects, but I bought some from Amazon. I don’t know what a m22 fitting is, sorry.
  10. Mar 27, 2019 at 5:07 AM
    War Machine
    Yes sir.
  11. Mar 27, 2019 at 6:25 AM
    MARanger
    MARanger Lost in the woods
    Andy
    Home of Friendly's Ice Cream
    2017 Super White SR5 DC 4X4
  12. Mar 27, 2019 at 6:37 AM
    spn4125
    spn4125 New Member
    ^^I have the same little Ryobi that I grabbed a few years ago on sale at Home Depot during their "spring black Friday" promotions. Other then the GFI on the plug breaking it has been great so far, and that was only a $5 fix. It is perfect in my opinion for washing cars, motorcycle, lawn mower, ect. and pulling out for the odd quick job. It is definitely undersized for siding and big projects but it will still get the job done, just at a much slower pace. Even if I upgraded to a gas unit I would still use this little guy for car washes.
  13. Mar 27, 2019 at 6:42 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    While you’re at it, this Ryobi water broom attachment is awesome especially for rinsing off road salt on warm days during the winter.
  14. Mar 27, 2019 at 8:40 AM
    briarpatch
    Even though not directed at me.....my SunJoe does have the quick disconnect at the end of the wand and worked with both of my foam cannons
  15. Mar 27, 2019 at 8:52 AM
    gdiep
    Syracuse, New York
    Thanks everyone.
  16. Mar 27, 2019 at 9:13 AM
    4Runner
    4Runner New Member
    Columbia, SC
    2017 Black Limited FFV
    Magnuson Supercharged, FOX 2.5 DSC front and rear, TRD Exhaust, TRD Rear Sway, and many more....build thread coming
  17. Apr 4, 2019 at 6:24 PM
    gdiep
    Syracuse, New York
    I bought the Greenworks 2300 recommended by @War Machine and it is a great power washer!
    I also bought the foam cannon recommended by @jtwags but haven’t tried it yet.
    The YouTube link from @4Runner was very good.
    Thanks guys.
    4Runner, jtwags and War Machine like this.
  18. Apr 4, 2019 at 6:30 PM
    I just purchased a Sun Joe on sale at HD online sales for 105.00.
    Next is the foam cannon.
    jtwags likes this.
  19. Apr 4, 2019 at 7:13 PM
    jtwags
    League City, TX
    2018 Tundra CM
    I just purchased the Tool Daily foam cannon from Amazon. Comes with 2 orfices. I installed the 1.1mm and tested tonight. Nice thick foam, simply satisfying to watch. Not a bad deal for $20.
  20. Apr 4, 2019 at 7:21 PM
    War Machine
    Sweet!
    ColoradoTJ likes this.
  21. Apr 4, 2019 at 7:26 PM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
  22. Apr 4, 2019 at 7:41 PM
    War Machine
    I’ve looked at those undercarriage washers also. I never clean mine.
    smslavin[QUOTED] likes this.
  23. Apr 4, 2019 at 9:08 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Good idea, but looks like poor execution? The nozzles look like they're spraying way too wide of an angle, so the spray looks like it's basically just misting the underside of the truck. The video was too long to watch so I never got around to finding out of the nozzles could be changed out. That should've been a 60s video, not 7+ damn minutes FFS.
    JoshuaA[QUOTED] likes this.
  24. Apr 5, 2019 at 4:11 AM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Not sure, I don’t have one, wish I did, they were clearing out for $20 at HomeDepot in Canada and sold out. I would probably change out for bigger wheels so they spray higher and it moves faster.
    Sas[QUOTED] likes this.
  25. Apr 5, 2019 at 8:30 AM
    Beavis
    Beavis New Member
    South Jersey
    2018 Cement Tundra TRD DoubleCab
    Sun Joe or Greenworks for an electric
  26. Apr 5, 2019 at 1:13 PM
    90b4032
    90b4032 New Member
    Kenny
    Black 2007 Crewmax 4X4
    BA Mufflers catback, Cold air intake,
    Find the Obsessed Garage Youtube channel. He bought every model of several brands of pressure washers and tested them. He is a fan of the Karcher k1700. Very informative videos.
  27. Apr 5, 2019 at 1:26 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I have a karcher k2 that I use around the house, cleaning maple syrup equipment, and my car. It's okay but definitely not a gas powered washer. Everything just takes a little longer. It did work well on my deck with a special rotary nozzle. It came with a foam sprayer that is awful and its funny you bring this up cuz I just got a MATCC foam cannon for it on Amazon and I'm pretty sure it's on my front porch right now.
    Just be aware that a lot of electronic power washer manufacturers have their own way of connecting parts and wands, so you'll need to buy adapters or brand specific parts.
    Edit just opened my amazon foam cannon that is made for karcher. I am shocked how heavy this thing is. Lots of brass and very little plastic.
