Electric parking brake not working after dash disassemble
Discussion in '3rd Gen Tundras (2022+)' started by uson7700, Aug 20, 2024.
  1. Aug 20, 2024 at 9:23 PM
    uson7700
    uson7700 [OP] New Member
    Hank
    2022 Lunar Rock Limited
    JB4 K&N Gibson exhaust Dobinson MRR shocks and springs
    After disassembling my dash to add Those sweet ambient lighting lights my dash say Parking Brake Malfunction and flashes the PARK sign. I did pull out the cluster that connects to the parking brake and hold switch/button and disconnect it. I did Not disconnect the battery for I was locating and tapping into power. Never had an issue before, any ideas?
  2. Aug 20, 2024 at 9:29 PM
    I'd check for a blown fuse somewhere. Always a risk when playing with electronics and not disconnecting the battery.
  3. Aug 20, 2024 at 9:41 PM
    uson7700
    Hank
    I have not I’ve been looking at the fuses and I’m not sure which one to check my app to check them all
  4. Aug 20, 2024 at 10:13 PM
    I'm not familiar enough with the 3rd gen Tundras to be any help in IDing a specific fuse. Just as a basic starting point that would be the first thing I checked. If that doesn't work, I would unhook whatever was added to see if it's causing a short.
  5. Aug 21, 2024 at 1:05 AM
    HLR_NM
    HLR_NM New Member
    Harry
    Try this:
    Engine running, turn off parking brake. Shut engine off.
    Engage parking brake, then start the truck.
    Sometimes this will clear the code.
  6. Aug 21, 2024 at 3:09 PM
    uson7700
    Hank
    Problem solved. I kept on fiddling with the parking brake by pulling the lever and pushing the Hold button and the lights eventually turned off. I can only think of that when I disconnected the dash while power was still going on the computer thought there was some electrical issue and that the electrical parking brake malfunction. I’m glad it didn’t go looking through fuses!
    HLR_NM likes this.
  7. Aug 21, 2024 at 4:40 PM
    HLR_NM
    HLR_NM New Member
    Harry
    It can be quirky. I threw the code by engaging the parking brake while barely moving in reverse. Glad you got it cleared :thumbsup:
