Electric bill....keeps rising...
Discussion in 'Off-Topic Discussion' started by VA10, Sep 13, 2016.
  1. Sep 13, 2016 at 7:21 AM
    VA10
    VA10 [OP] New Member
    2020 Tundra Limited TRD Off-Road
    Good morning,
    Our power bill keeps going as of three months ago. I cannot pinpoint why.
    Items we consistently use.
    SONOS - calculated the idle power consumption and in use power consumption (not as signifgant as I thought.) - i do not think this is the issue.
    2 play 3s
    1 play bar
    1 sub
    Large Fridge
    Small beer Fridge
    Kegerator
    3 flat screen TVs (no more than 2 on at a time)
    Xbox ones (on for a min of 3 hrs mon-frid)
    A/C unit - we rarely set it to cool if the outside temp is over 92 degree F.
    Ceilling fans - 2 are on very often - through out the night all the time.
    I am honestly racking my brain here. Because at first there was a trend with the SONOS speakers but after doing the calculations the bills are way higher than the SONOS could cost to idle all the time/use. Anything I could be missing?
    the bill has jumped over $100 a month.
  2. Sep 13, 2016 at 7:36 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Are your fridge doors closing all the time?? Could even be a worn weatherstrip, maybe you guys forget to turn off a DVD player or something without realizing it, something small like that?
    driverdog and NewImprovedRon like this.
  3. Sep 13, 2016 at 8:03 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    only $100 a month? i wish :)
  4. Sep 13, 2016 at 8:21 AM
    Do your rates increase over the summer?
  5. Sep 13, 2016 at 8:27 AM
    GoHuskers
    GoHuskers New Member
    Nebraska
    '24 iForceMax, '17 RX350, '15 GX460
    $100/month is not bad..I average $150/month (no gas, just electric)....little higher on cold winter months and little lower for Apr-Jun and Sep-Oct...since they are cooler months. My electric rates are higher in summer months.
  6. Sep 13, 2016 at 8:28 AM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    Problem solved!
    Seriously though, is it possible someone is stealing your service? Do you have access to the meter and fuse panel? You could troubleshoot by switching off all of the fuses but the main disconnect, and then enabling them one at a time and then watching the meter. If you identify a circuit that spins the meter very quickly you can at least isolate which circuit is the culprit and go from there.
  7. Sep 13, 2016 at 8:28 AM
    Backslider
    Tooele, UT
    I'm pretty sure he was saying his bill has gone up by $100 recently - not that $100 is his total bill.
    NewImprovedRon likes this.
  8. Sep 13, 2016 at 8:30 AM
    GoHuskers
    Nebraska
    ...then he has bigger problems....turn off everything except your beer fridge.
    Backslider[QUOTED] likes this.
  9. Sep 13, 2016 at 8:51 AM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    What size of house? I live in an apartment right now (1200 square feet) while my house is being built and my power bill hovers right around $100.
  10. Sep 13, 2016 at 9:13 AM
    In VA, starting in July 2016, you had a reduction in rates. Not the cheapest rates in the lower 48, but certainly not the worst. Jumping up 100.00 is a pretty significant cost at 7.01 cents per kWh. (I am at 4.45 cents per kWh)
    I would look at all your higher voltage items in the house:
    Dryer-sometimes a coil goes out and takes 3x longer to dry a load and on 110V is very inefficient to say the least.
    Range- do you have gas or electric?
    AC- you could have a compressor going south and drawing more amps
    Refrigerators- Same issue as AC
    Next I would have the meter checked by the utility company. My wife ran a meter shop for years and they do fail. Meter swaps are easy for the company to do for insured performance to the customer.
  11. Sep 13, 2016 at 10:29 AM
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    I'd suspect the AC unit first. Clean the compressor coils, change the filter, and check the inside coils for accumulated crud. Put a thermometer in the output vent farthest from the unit. That will tell you if the unit is cooling correctly. The house may stay cool, but it will take a while to get there, and a lot of running to stay there, if your AC needs service. For the inside appliances, get a Kill-A-Watt device and see what they're using. Clean out the dryer vent hose, that will create back pressure and take longer to dry clothes. Last, turn off all political speeches on the radio and TV. That much hot air has to have a negative effect on cooling the house in the summer.
  12. Sep 13, 2016 at 12:49 PM
    VA10
    Ok - I will try my best to answer all of your questions.
    1. I live in a 3 bedroom apartment which overhangs above my garage.
    2. stove/range/oven is gas. Including our fireplace
    3. Our A/C is clearly not top of the line equipment. In fact the only portion of the HVAC system I have access to is the filters and thermostat. We change the filters approx every 30 days. I use to work in the HVAC industry and know not to set the thermostat to high temp when its very hot out or turn it off all together during the hotter points of the day. We already ran some experiments regarding the HVAC.....none relieved significant impacts on the electric bill.
    4. We do tend to dry our clothes using a "low heat" setting on the older style dryer which makes for multiple cycles before clothes are dry. (trying to prevent clothing from shrinking).
    5. one mini fridge in the garage stays plugged in 24/7 - So i am think maybe be t-stat is exposed to the warmer temps 24/7 is causing it run all the time. this also goes for the kegorator.
    and to clarify my bill has increased a tad of $100.
    THANK YOU FOR ALL THE INPUT AND ADVICE!
  13. Sep 13, 2016 at 12:50 PM
    VA10
    Ahhh good point. I will have to check w/ my girl friend. most of the bills are emailed to her directly........
    SouthBoundSteve likes this.
  14. Sep 13, 2016 at 1:54 PM
    Only other question I would have is how your electric is metered? Do you share with others and then devided up?
    driverdog likes this.
  15. Sep 13, 2016 at 3:32 PM
    Ryan Mc.
    Ryan Mc. New Member
    Ryan
    Mission Viejo
    2015 Toyota Tundra SR5 Double Cab 5.7L
    Hand made bed divider, bed d-rings
    Buy Solar...ours is $300-$350 annual payment. We OWN it...only way to do it. Do not lease.
    Our home came with solar already installed (4 panels) we upgraded and added 2 more. Forgot to mention we bought a new home.
    Sunpower is the manufacturer.
  16. Sep 13, 2016 at 3:43 PM
    Ryan Mc.
    Ryan Mc. New Member
    Ryan
    Mission Viejo
    Word to the wise...I live in SoCal, electric company is SoCal Edison. We received a notification in the snail mail a few months back basically stating that if a house generates TOO much electricity compared to the amount they are using that house will automatically be billed a minimum of $10.
    EX: A family of 8 buy 20 panels, which at the times makes sense for them. They pick up their S*** and get out of dodge. A family of 2 buys the house. The electricity usage drastically decreases compared to what the panels generate. That family of 2 get a bill of $10 per month just for S***s and Gigs.
