Efn Mice!!!
Discussion in '2.5 Gen Tundras (2014-2021)' started by YorkT, Jun 16, 2022.
  1. Jun 16, 2022 at 8:51 AM
    YorkT
    YorkT [OP] New Member
    Ok, so this isn't Tundra related, but it happened to my daily driver, 2001 Corolla. My Tundra gets to stay in the garage most days, so maybe that counts. My check engine light came on a couple of weeks ago, so I pulled the code and got a P0171 (system too lean). Possible causes were a dirty air cleaner, dirty MAF sensor, clogged fuel filter, etc. I checked the air filter first and found that some little shit decided to make a nest in the air filter compartment.. I cleaned everything up and replaced the chewed up air cleaner and cleared the code. The next day the CE light came back on. I pulled the MAF sensor which was visibly dirty probably from the hole in the air filter. Cleared the code again and it hasn't come back on for a couple of days now. I set a trap at the front wheel of the car and caught 1 mouse. Yesterday i went to get a pair of neoprene work glove out of the box and found a nest in there. I set a trap last night in the garage and it wasn't even touched. Hopefully the one that was already dead did the second nest too.
  2. Jun 16, 2022 at 8:55 AM
    Taco-Spike
    Two Trucks
  3. Jun 16, 2022 at 8:58 AM
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    There's a vent under the cowling where the wipers are and another one in the trunk that is covered with a plastic grill that mice can enter the car through. Had a nest of babies in my older Camry back there years ago. Aluminum screen or 1/4" hardware cloth will fix your issues.
  4. Jun 16, 2022 at 9:57 AM
    YorkT
    Hi hope it doesn't come to screening everything. I'm hoping that it was a one time thing and I caught him. Still going to leave some traps set.
  5. Jun 16, 2022 at 10:16 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Is it dark where you park the corolla? I found that if you have light they are far less likely to go into the lit area.
  6. Jun 16, 2022 at 10:33 AM
    YorkT
    Not dark, I park right under a dusk to dawn light at my garage. My lot has a weird layout, my front yard meets up with several back yards to the people that live in front of me. One neighbor decided to park his new car hauler trailer ( which he only stores junk in) and a camper right to the property line of my front yard. It is nice and dark there. I could only hope that mice can make a nice home in his camper and trailer.
  7. Jun 16, 2022 at 10:47 AM
    MadMaxCanon
    sounds like you need to throw some bait under his camper....................
  8. Jun 16, 2022 at 10:48 AM
    MadMaxCanon
    consider peppermint oil mixed with water to spray around engine bay, or soak some cottonballs with it and throw them in the engine bay. Worst thing that can happen is you get a nice smell when you turn on the AC.
    Wallygator likes this.
  9. Jun 16, 2022 at 10:56 AM
    YorkT
    Believe me, I have seriously thought about it.
    MadMaxCanon[QUOTED] likes this.
  10. Jun 17, 2022 at 11:42 AM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Honda is now selling a rodent tape to wrap your wiring
  11. Jun 17, 2022 at 11:54 AM
    YorkT
    I hope it doesn't come to that. I have been in my house for 30 years and never had something like this going on. One of the traps that I have in the garage had the bait taken off of it last night, so i still have a least 1 more. I will have to set it closer to a hair trigger to get this one.
  12. Jun 17, 2022 at 12:02 PM
    Makoy339
    Makoy339 Simplicity = Reliability !!!
    Super White TRD
    TRD parts
    Used one of this repellent in my dads Merc after finding roddent droppings under the hood.
    Works well so far. Havent found any trace of roddent activities under the hood after installing this device.
    And its on sale - 50%off. For $10 - why not give it a shot.
    https://www.amazon.com/gp/product/B09H73PQY6?ie=UTF8
  13. Jun 17, 2022 at 12:34 PM
    YorkT
    Great price, definitely worth a try. Thanks!!
  14. Jun 17, 2022 at 2:04 PM
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    Did you check the cabin air filter as well?
  15. Jun 17, 2022 at 5:47 PM
    rds95991
    rds95991 New Member
    2018 Super White Tundra CrewMax SR5 TRD
    That's what happens when you use plant based plastics as an attractant.
  16. Jun 20, 2022 at 9:14 PM
    BigT27
    BigT27 New Member
    I swear everytime I check my filter I always have my fingers crossed I don't see something like this. Sorry it happened bro
  17. Jun 21, 2022 at 7:54 AM
    Kichinko
    Kichinko New Member
    TRE 5ON
    VA
    SUPER WHITE 2016 Plat 4x4
    TBD
    Just got my truck back from the shop recently, 400 bucks later (Mice ate a sensor wire) Quite a surprise when the dash lights up like this...20220520_094213.jpg
  18. Jun 21, 2022 at 9:10 AM
    trevorklat
    trevorklat Don't Mess with Texas!
    The Lone Star State
    2018 Super White Platinum Tundra 4WD CM
    Linex bed liner, Retrax roll-top bedcover, Ranch Hand Summit brush guard, SDHC ABS sensor guards, Interior LEDs, Cargo lamp LEDs, Reverse Light LEDs, Rear TRD sway bar, Valhalla's Shield Cat plates, Husky floormats
    MIce are like roaches...if you see one you, actually have ten. If you see ten, then you have a major problem!
  19. Jun 21, 2022 at 12:18 PM
    pursuit2550
    pursuit2550 New Member
    I had a similar issue with the wifes Lexus NX300. Mice where making a nest and ate up the wiper fluid hose. Thank goodness it wasn't any wires. So I cleaned it all out, fixed the hose and went to Home Depot and bought those green poison blocks. Broke one up in little pieces and put them around the engine bay. Waited a few day and when they where gone I added more. When I noticed that it was still there, then that meant the little fucker was dead. I still put some every once in a while just to make sure. Normally I can tell if they are back because they will piss on the intake manifold cover and you can smell the piss as soon as you pop the hood. So you could give that a try, they love those green blocks.
  20. Jun 21, 2022 at 12:29 PM
    Retired...finally
    I have a beater 1967 Wheelhorse tractor used solely for maintaining my long, steep gravel driveway. Keep it under a tarp outside. Mice love to get in around the Kohler flywheel and build a nest. The flywheel just hacks them up and spits out little mouse bits when I start it up. I laugh and plow gravel.
    Black Wolf and YorkT[OP] like this.
  21. Jun 23, 2022 at 3:11 AM
    YorkT
    There is no cabin filter. I did check just to make sure. I guess they were not a thing 20+ years ago.
    Black Wolf likes this.
  22. Jun 23, 2022 at 12:16 PM
    34ford
    34ford New Member
    2018 sky silver DC 5300 miles
    none yet
    Tom Cat Rodent repellent, Lowes-HD Sell it works GREAT!!!!!!!!!!!!!!!!!!
  23. Jun 23, 2022 at 3:57 PM
    19TurdPro
    2019 Tundra TRD Pro
    There should be one. You access it from under the glove box.
  24. Jun 23, 2022 at 5:08 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    This works, i use one in my deer lease trailer which is personless many months of the year, not a single poop dropping. It makes loud (to a mouse) banging type random sounds, its slightly audible so I turn it off when I arrive with my dog. It'll work anywhere it stays out of rain.
    Mice also don't like the smell of bleach. Bleach smell sticks around a while, so I spray a 50-50 mix all around the trailer or car, whatever to further deter them, bastxrds....
    https://www.amazon.com/Mouse-Blocke...t=&hvlocphy=9028293&hvtargid=pla-372389684838
  25. Jun 23, 2022 at 5:26 PM
    Nueces
    Nueces New Member
    Texas Hill Country
    2002 Tundra SR5 AC
    One shop found a rodent nest in my 2002 Tundra's air filter housing. He stores older cars on his property and uses this product, one pouch in each filter housing. I park outside, too. I tried it and it works. Instructions advise change out every month, I get away with every two months, which works out to $3 for 60 days of protection.
  26. Jun 23, 2022 at 5:52 PM
    Sucks but there is always a silver lining.....take those bird feathers and take up fly tying......
    YorkT[OP] likes this.
