ECU swap
Discussion in '2nd Gen Tundras (2007-2013)' started by Ant1227, Dec 12, 2023.
  1. Dec 12, 2023 at 9:02 AM
    Ant1227
    Ant1227 [OP] New Member
    Anthony
    2016 Tundra Platinum
    I have a 2016 Toyota Tundra supercharged. I swap the ECU/ECM, the trucks runs and drive but it lack in power like in limp mode, no boost. No codes, Does the ECM have to be programmed to the rest of the ECUs in the truck?
  2. Dec 12, 2023 at 10:43 AM
    texoma
    texoma Triple C Chop Shop
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
    The ECU needs to have the same SC program as the one that came out
  3. Dec 12, 2023 at 12:28 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    What @texoma said... Not sure why you swapped out your original ECM/ECU, but I would go back to it, since it may be tuned to your SC. If you were in limp mode with the original ECM, maybe look into the SAIS issue as it drops you into limp mode to save the engine. If that's not it, then go down your regular maintenance check lists. Check fluids, especially your transmission and acquire a data logger, or something you can view live data and troubleshoot what the original issue was, if you have any.
  4. Dec 12, 2023 at 2:01 PM
    Ant1227
    Anthony
    The new ECU has the SC tune in it also. I switched back to the original ecu and it’s has the same problem. It’s something in the programming
  5. Dec 12, 2023 at 2:07 PM
    texoma
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
    do the Cal ID’s match on both ECU’s?
  6. Dec 12, 2023 at 3:22 PM
    Ant1227
    Anthony
    I have a feeling it doesn’t match. What the procedure to do this? I have techstream as well
  7. Dec 13, 2023 at 4:13 AM
    texoma
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
    You can open tis and log in. Search your year and model, and type in just super charger. It will bring up installation instructions. Click on that, scroll to the bottom and select your cal id. Make sure it matches the current ECU cal id.
