  1. Jul 20, 2025 at 8:32 AM
    Tundranewbie5010
    Tundranewbie5010 [OP] New Member
    I need some ideas please! I'll try to be brief: Was having rando codes for over a year, almost went broke replacing parts that weren't really bad. Clearing the codes with my $50 scanner worked for a few weeks at a time. Codes got more frequent, bought a used ecm on ebay, did the youtube paper clip reprogramming/reset trick, truck cranks but no start (immobilizer?). All kinds of codes and flashing icons. Put the old ecm back in, same thing. Now I have a giant paperweight in my driveway
  2. Jul 20, 2025 at 8:35 AM
    Tundranewbie5010
    Btw, its a 2008 5.7L
  3. Jul 20, 2025 at 8:39 AM
  4. Jul 20, 2025 at 8:49 AM
    Tundranewbie5010
    Any hack to sync the vin without calling a towtruck? Thanks
  5. Jul 20, 2025 at 8:52 AM
    Tundranewbie5010
    Also why wont the old ecu work if its just vin locked?
  6. Jul 20, 2025 at 9:23 AM
    I would be willing to bet the anti theft immobilizer is in full effect.
    You will need a shop/friend with a lot nicer scanner (think snap on) to clear codes and figure out the root problem.
    I have a spare ECM for my jeep due to some bad diagnostics that cost me 1600.00. Once the ECM was programmed we couldn't remove the vin lock. Sucked because it was a 50.00 part that ended up being the problem.
    T-Rex266 likes this.
  7. Jul 20, 2025 at 9:27 AM
    Tundranewbie5010
    Thanks for the reply. Could a toyota dealer reprogram the ecu and vin if i just take them the ecu (without the truck attached:))?
  8. Jul 20, 2025 at 9:45 AM
    bflooks
    bflooks New Member
    Metrowest MA
    Possibly, but they probably won't. It should be a 1 hour diagnostic fee to have them reprogram the VIN for you. Orrrrr, you go down the path of techstream.
    You can search this forum for ECU recovery and it'll get you sorted. You're not the first.
    Regarding the old one not working, if it was already on its way out, the power loss could have just sealed its fate.
  9. Jul 20, 2025 at 9:47 AM
    Tundranewbie5010
  10. Jul 20, 2025 at 9:57 AM
    bflooks
    bflooks New Member
    Metrowest MA
    Mdl likes this.
