eco mode vs normal mode
Discussion in '3rd Gen Tundras (2022+)' started by dxk9, Mar 8, 2025.
  1. Mar 8, 2025 at 6:20 AM
    dxk9
    dxk9 [OP] New Member
    DJohn
    Hi,
    I have a gas 2022 tundra sr5.
    When I scroll around on the window I see eco for gas in green. Some one posted he got better gas mileage in normal mode for gas however I don't see how to switch between eco and normal mode, RE: fuel.
    Thanks,
    ~DjK
  2. Mar 8, 2025 at 6:31 AM
    Observer
    Observer New Member
    dxk9[OP] and Raven67 like this.
  3. Mar 8, 2025 at 6:31 AM
    Butcher23
    Butcher23 New Member
    2025 Blueprint Tundra
    Hi DjK,
    Big knob on the center console next to the 4x4 settings. You can turn that knob to set either Normal, Sport or Eco modes. I'm pretty sure all it does is change shift points.
    Mark
    dxk9[OP] likes this.
  4. Mar 8, 2025 at 6:37 AM
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    Eco mode seems to lower the throttle response. I hated it when I tried it. Actually got better mileage in normal mode myself.
  5. Mar 8, 2025 at 6:54 AM
    dklehman
    dklehman New Member
    Darin
    2024 sr5 Tundra
    Also sport mode is fun. Tow+ ( tow mode and sport mode together) is even better.
    Maharisc, ScottieBones and dxk9[OP] like this.
  6. Mar 8, 2025 at 9:08 AM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    Same here. Eco makes the truck feel sluggish and it seems to make the trans hunt for the correct gear more. I also get better mileage in Normal mode.
    Tow + Haul Ass mode is bit too aggressive for me for every day driving, but it's fun for interstate on ramps, or blowing little ricers off the line at stop lights. LOL.
  7. Mar 8, 2025 at 11:18 AM
    TundBP
    TundBP New Member
    23 Blueprint Platinum
    I leave mine in normal. No discernable difference in my MPG, with a more responsive go pedal.
    Raven67 likes this.
  8. Mar 8, 2025 at 11:35 AM
    Frank_TRD23
    Frank_TRD23 New Member
    2023 Tundra TRD Mag grey
    1.5 Wescott lift 20" wheels on 37s Stillen Trucontroller
    Mine gets better mileage on off mode. I don't see a different in mine in all three modes.
    TundraDan723 likes this.
  9. Mar 8, 2025 at 3:24 PM
    JH8473
    JH8473 New Member
    2025 Tundra SR5
    None
    If I drive 68 MPH, i can achieve 24 MPG.
    If i drive 70 MPH, i on only get 18 MPG? WTF.
  10. Mar 8, 2025 at 3:52 PM
    JH8473
    JH8473 New Member
    2025 Tundra SR5
    None
    ECO mode sucks.
    cartage1 likes this.
  11. Mar 8, 2025 at 4:22 PM
    Matt2015Tundra
    2023 1794 CrewMax
    For me, a steady 55-60 mph is the sweet spot at around 22-23 MPG. Anything faster, that requires the boost to kick in occasionally, drops the MPG significantly. Throw in some steep inclines, headwinds, or variable traffic speeds and 17-18 is pretty common.
    I've traveled cross country in mine 4 times. The overall best MPG I've got was 17.2, but that included food and fuel stops, variable weather and traffic conditions, wife and 2 large dogs, and a full bed of vacation stuff. Still significantly better than my 2015 Tundra. And the range of the 32 gal fuel tank is an extra bonus on those long roadtrips.
    Soupbean77 and Ausfahrt like this.
  12. Mar 8, 2025 at 4:24 PM
    1794LE
    1794LE New Member
    Shane
    2024 Blueprint
    Eco mode is good if you want to use the electric function more around town and in stop and go. Other than that, I haven’t seen any other benefit
  13. Mar 9, 2025 at 9:59 PM
    sandiegosteve
    sandiegosteve New Member
    San Diego
    24 Limited TDR Lunar Rock
    Eco mode seems to make it lug particularly if there are any hills. I've done a few simple tests. Eco gets worse MPG than Normal. Sport can be better when I'm in hilly areas. Eco might be better on a flat road that is stop and go, stop signs or stop lights. For anything else, Eco seems to be worse MPG.
  14. Mar 10, 2025 at 4:58 AM
    Rockpig
    Rockpig You did what?
    08 Limited
    What I'm curious about is what does the "Drive Mode" button do? When I push it, it does nothing, light is always lit.
  15. Mar 10, 2025 at 5:08 AM
    Raven67
    Kentucky
    You need to turn the knob, that will adjust to the different modes via a notification on your dash.
  16. Mar 10, 2025 at 5:17 AM
    Rockpig
    08 Limited
    That I understand, I'm trying to figure out what the purpose of the button is, light is always on and nothing happens when I push the button.
  17. Mar 10, 2025 at 5:45 AM
    Alex261
    Alex261 New Member
    Alex
    Boston, Ma
    2024 Tundra Platinum LR
    Push the tow/haul button and that will no longer be lit. It’s the default
    sandiegosteve and Matt2015Tundra like this.
  18. Mar 10, 2025 at 7:14 AM
    teab
    teab 2023 Platinum w/ PRO bits
    Ty
    Denver
    2023 Platinum MGM 6.5
    TRD Pro Wheels, Go Rhino D6, Airlift bags/compressor, Talons Alum Cat Shield, Cheap-o Amazon Mud Flaps, Fastop Tonneau/Topper, Rear TRD Pro Shocks
    The formula for wind resistance, also known as drag force, is: F_d = (1/2) * ρ * v^2 * C_d * A
    The V (in the formula ft/s vs mph) in there is velocity and its squared when calculating drag force so even though it just seems like a a couple miles per different it makes a bigger difference than you think considering drag....that 2mph difference comes out to about a 6% increase in drag force. As speed doubles the force quadruples.
    Probably about the tipping point of being in boost sometimes and out of boost most the time. I've seen similar results 65mph and get 20+mpg and go 75mph and get about 18mpg. Towing my little camper/cargo trailer/toy hauler its about 14mpg vs 11mpg.
    Soupbean77 likes this.
  19. Mar 10, 2025 at 9:12 AM
    Soupbean77
    Soupbean77 New Member
    2023 Mag Grey Tundra Limited Crewmax 4x4
    Resistance… be it road and rolling, as in larger contact patch (bigger tires). Headwind, (air blowing against you) and air resistance (being the faster you go the more resistance you get). All will affect your mileage dramatically. Then you have a lifted above stock height truck, maybe with the lower air dam removed causing more underbody turbulence and aggressive off road tires..
    It is a large truck after all, I knew before I bought it that mileage wasn’t my top priority.
  20. Mar 10, 2025 at 9:35 AM
    Tundra@AZ
    Tundra@AZ New Member
    2021 MG Tundra
    I threw mpg out the window when I bought a tundra.
  21. Mar 10, 2025 at 11:39 AM
    Ausfahrt
    Ausfahrt New Member
    Vermont
    2024 SR5 4X4
    When I bought my Tundra they told me that there would be no math.
  22. Mar 14, 2025 at 7:53 PM
    Dirtsurfer83
    Dirtsurfer83 New Member
    Olalla, WA
    '23 Tundra TRD
    Dobinsons IMS 2/1 Method 703 Toyo RT Trail 35x12.50r17
    Does the eco/normal/sport mode have to do with fueling, or shift points?
  23. Mar 15, 2025 at 3:01 AM
    Lots-O-Dogs
    Lots-O-Dogs New Member
    Mark
    I drove a random 25 miles in economy and regular mode. I found the mileage to be better in regular mode. I also found that economy mode made the truck feel sluggish. Living in New Hampshire, I found that economy mode was actually beneficial to use in snowstorms- it took a bit of the “edge” off. Past that? Meh.
  24. Mar 17, 2025 at 11:08 AM
    Butcher23
    I have also been playing with the different drive modes, I seem to get the best mileage and performance in Sport Mode. All the different modes do is tell the transmission what RPM to shift at. That's why ECO mode feels so sluggish, it shifts at such a low RPM, at least that's been my experience.
    sandiegosteve and BlackNBlu like this.
  25. Mar 17, 2025 at 11:36 AM
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    24 Limited CM 5.5 Blueprint TRD OR
    5100's, 285/75/18, Air Lift bags, bits and bobs
    Sport mode is MY default, daily driving setting. I wish I could make it the truck's default.
    Tow or Tow+ is if I need(?) to have fun or show off. Or actually tow. Works well for that too. :D
    I still get 18 to 20 commuting if I keep my foot out of it, with a noticeable reduction in off the line hesitation / stumble.
    I haven't been able to get any better mileage in Normal mode day to day.
    I'll use ECO on a (non-towing) road trip only.
    Works for me. YMMV.
    Butcher23 likes this.
  26. Mar 17, 2025 at 8:02 PM
    PNW Tundra Mike
    Southern Cal
    MX4 Tonneau, Talon's Trans/Cat Shield
    Besides shift points; ECO also shortens A/C compressor cycle times. Throttle response seems different as well. Sport mode is said to also affect steering response giving a tighter feel. Just remember Tow/Haul modes limit Trans OD use. I’m not positive of the difference between the two with OD. Need to test that.
