Ecm reflash?
Discussion in '2nd Gen Tundras (2007-2013)' started by Essarefive, May 23, 2024.
  1. May 23, 2024 at 1:30 PM
    Essarefive
    Essarefive [OP] New Member
    Hello, I have a 2008 4.7 4x4. Having a hell of a time with the SAIS. Does anybody have an ecu reflash to ignore all of this BS? The truck is being used for off road purpose only.
  2. May 24, 2024 at 7:04 AM
    Essarefive
    Maybe I should have posted in the tuning section, could somebody move it?
  3. May 24, 2024 at 7:44 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Have you done the SAIS bypass on it? if it's offroad it shouldn't be an issue to bypass inspections items.
  4. May 24, 2024 at 8:15 AM
    Essarefive
    Yes. It would take me forever to explain but I think the best option is to find someone or someway to flash the ecm with a tune that ignores the sais
  5. May 24, 2024 at 8:28 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Yea you can turn off the CELs for it and disable the throttle limp mode in a couple softwares.
  6. May 24, 2024 at 8:48 AM
    Essarefive
    Awesome, what software?
  7. May 24, 2024 at 9:29 AM
    snivilous
    SW UT
    HP Tuners can, probably VF Tuner, I'm not sure if D3 Performance can but they'd be the last option.
    And to be clear, I think you can disable that shit as much as possible and the truck should act and look totally fine. But I don't know if there's some tables or values that are inaccessible and might still fuck with things. The only thing I've seen is the limp mode throttle table for the secondary air fault, and then the CELs that can be turned off, but I haven't personally had your issue to see if it still behaves normal from doing those changes.
    Leo's first likes this.
