Easy way to interchange tonneau cover and Softopper
Discussion in 'Tonneau Covers, Caps and Shells' started by dadtrucklife, Mar 13, 2025.
  1. Mar 13, 2025 at 11:19 AM
    dadtrucklife
    dadtrucklife [OP] New Member
    2021 SR5 TRDOR 4x4 (Army Green)
    I currently have a Bakflip tonneau cover mounted using the oem bed rail system. I would like to get a Softopper for camping trips but what a hassle to have to swap mounts and rail systems. Is there an easier way? How about if I buy a second set of oem bed rails and swap bed rails so the mounts stay in place and I only have to remove and install the torx holding it into the bed. Would this work or make sense? Any other clever solutions?
  2. Mar 13, 2025 at 11:51 AM
    DrRansom
    DrRansom New Member
    Utah
    Silver Sky 2021 SR5 Tundra 4WD
    Seems like removing the rails would be as big of a pain if not bigger
    AZBoatHauler likes this.
  3. Mar 13, 2025 at 12:17 PM
    dadtrucklife
    Could be but haven’t tried. My thinking is that atleast the tonneau cover and Softopper mounts will remain intact so there is no need to realign anything. Just bolt the rails back into their holes. I could be under thinking it.
  4. Mar 13, 2025 at 2:24 PM
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
    https://fas-top.com/fas-top-travele...X6STITnq5f9ZBjLKMW4FhcwjUzQT8Dp58RvHy6KlH4AA9
    I don't know anything about this but I remember seeing some members here who put them on... Reportedly it is both softoper and soft tonneau
    BoysandHisToys likes this.
  5. Mar 13, 2025 at 4:47 PM
    BoysandHisToys
    BoysandHisToys New Member
    Central Virginia
    2013 Tundra Crewmax Limited
    12” Bulletproof Lift, AFE CAI, AFE Exhaust, rock lights, Fas-Top tonneau and soft topper, Dasaita 10.2” radio, light bar, ditch lights, LED headlights and fog lights, LED interior lights, Amp Research rear bumper step, dashcam, BT ODBII reader and Torque app on radio
    I have this and would recommend it to anyone. The soft topper stores under the tonneau cover towards the front of the bed. Roll the tonneau cover up to the front and pull the soft topper up.
    It does leave a little gap between the soft topper and cabin, but the flexibility of having both is worth it. It even works with the Decked system.
    MAC25Tundra and APalmTree like this.
  6. Mar 13, 2025 at 5:43 PM
    biebs96
    PA
    do you have photos of this. Because this sounds like a really nice set up.
  7. Mar 13, 2025 at 5:46 PM
    BoysandHisToys
    Central Virginia
