Easy 5 min anytime fog light relay mod DIY
Discussion in 'Lighting' started by xtyfighterx, Jan 16, 2018.
  1. Jan 16, 2018 at 9:31 AM
    xtyfighterx
    xtyfighterx [OP] New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    so there’s a lot of write ups on the anytime fog light mod using wires under the dash etc I found a different way which is simpler. If someone has already posted this please delete. There is also a YouTube video on a. 2nd gen from years ago you can reference if you want to add a aftermarket switch.
    This was performed on my 2015 sr5. And should be compatibile with 2nd and 3rd gen tundras. Iam not reliable to any damages caused to your vehicle :).
    Cons:fog lights will not be controlled by the fog light switch. They will come on automatically with Parking lights,low beam, and hi beam. To turn them off you must turn off all lights(minus your DRL)or wire a separate switch in. For me if my headlights are on my fogs are and I wanted to be able to have them on with my parking lights and brights so this is perfect for my situation here’s a breakdown.
    Looking at the fuse box
    Locate the foglight relay
    Using pliers Pull the relay outward.looking at it from this angle the bottom left prong is the one u want.bend it slowly with pliers to a 90 deg and connect a female spade to it with about 12in of wire.
    Plug your relay back in and run the wire to a good grounding point,cut the wire to proper length and connect using the proper connector(which I need to add to mine I couldn’t find any in my shop).
    Install your fuse box cap and test your lights. The fogs no longer are controlled by the fog light switch. They will be controlled by your main light switch. Fogs with come on with the parking lights, headlights, and hi beams. Only way to shut them off will be to turn off all lights or wire in an aftermarket toggle/rocker switch.
    Finished product
    Video to run a aftermarket switch if wanted. Not my video.
    https://youtu.be/-kfzNGUAs-A
  2. Jan 16, 2018 at 9:32 AM
    xtyfighterx
    Ty
    North Idaho
  3. Jan 16, 2018 at 9:37 AM
    darkknight2014
    darkknight2014 Mods mods and more mods!!
    Phil
    New york
    2014 tundra sr5
    20" Cooper STT Pros on md rims, quadfire lights, pro grille, leather interior, navi, retrofitted headlights, blacked out chrome, TRD sway bar, hypertech interceptor, k&n air intake, Banks exhaust
    Nice write up!! Next on the to do list.
  4. Jan 16, 2018 at 9:53 AM
    BakNBlk2014
    BakNBlk2014 So Impossibly Black
    Donald
    Virginia Beach VA
    2014 limited cm attitude black 4x
    BDS 4 1/2 Nitto Terra Grappler 35x12.5/18 BW Fender Flares Moto Metal 970 Wheels Leer Tonneau Bed Cover Black Plastidip Grill CF Wrap Interior AJT Shift Knob 35% Tint Weather Tech Mats Toyota Bed Mat AFE Intake
    Added. Thanks.
    xtyfighterx[OP] likes this.
  5. Jan 16, 2018 at 11:54 AM
    BakNBlk2014
    Donald
    Virginia Beach VA
    Subscribed
  6. Jan 16, 2018 at 1:55 PM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    Looks great with those new headlights!
  7. Jan 16, 2018 at 2:04 PM
    xtyfighterx
    Ty
    North Idaho
    Thanks I agree now I need some rigids In there
  8. Jan 16, 2018 at 2:21 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
  9. Jan 16, 2018 at 2:24 PM
    Berdine
    Binghamton, NY
    Better share!
  10. Jan 16, 2018 at 2:39 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    I'll even save you a seat on the bench
  11. Jan 16, 2018 at 4:16 PM
    darkknight2014
    Phil
    New york
    2014 tundra sr5
    Lets get it going on the rigids. Lol
    4x4_Angel likes this.
  12. Jan 16, 2018 at 4:49 PM
    xtyfighterx
    Ty
    North Idaho
    Next mod for sure
  13. Jan 16, 2018 at 5:04 PM
    darkknight2014
    Phil
    New york
    2014 tundra sr5
    Im trying to find a plug and play that goes to the stock harness.
  14. Jan 16, 2018 at 5:10 PM
    epa4wd
    epa4wd New Member
    Ed
    Nice!. On mine (2018) the fog light relay is the one next to your finger on the right and the relay is negative switched, so I wired it to the negative of the headlight relay. When headlights are switched on, headlight relay coil is grounded and the fog light relay coil will be grounded too thus turning on the fog lights.
  15. Jan 16, 2018 at 5:29 PM
    xtyfighterx
    Ty
    North Idaho
    Right on! Same conecept here I believe just grounded in a different spot
    epa4wd[QUOTED] likes this.
  16. Jan 17, 2018 at 5:18 PM
    xtyfighterx
    Ty
    North Idaho
  17. Jan 17, 2018 at 5:23 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Gonna try this when the temp gets up over 20.
    Seems nice and easy and I've been hoping for a tacoma-like fog light mod
  18. Jan 17, 2018 at 5:26 PM
    Pudge
    CT
    I wonder if the ground wire could somehow be connected to the stock fog light switch. (Too bad its not a push button switch)Would be tough but would restore use of the switch.
  19. Jan 17, 2018 at 7:52 PM
    xtyfighterx
    Ty
    North Idaho
    Idk the stock fog switch is kinda dumb on our trucks like you said wish it was an actual button. You can do the mod under the dash if you wanna use the switch but, for me before I did this mod id keep them on full time no matter what but wanted them on with the parking lights to accent the fogs so this made more sense to me. You can always wire in a oem fog light switch like the Tacoma’s have to keep your on off option to
    That’s what the guy in the video did but used a toggle
    4x4_Angel, Pudge and darkknight2014 like this.
  20. Jan 21, 2018 at 8:24 PM
    xtyfighterx
    Ty
    North Idaho
    Bump hope other members can take advantage of this.
    Pudge likes this.
  21. Jan 21, 2018 at 8:25 PM
    darkknight2014
    Phil
    New york
    2014 tundra sr5
    Ill be doing this tomorrow when i put the rigids in!!
  22. Jan 21, 2018 at 8:51 PM
    TheBeast The Beach
    very cool ! thumbs up ! too bad I can't have fog On all the time...city of L.A. and all the Prius drivers are hatin on me.
  23. Jan 21, 2018 at 9:36 PM
    xtyfighterx
    Ty
    North Idaho
    Did U figure out plug and play? I’ll be getting a set next payday
  24. Jan 22, 2018 at 5:07 AM
    darkknight2014
    Phil
    New york
    2014 tundra sr5
    Yeah, thats a negative on that. I emailed the member that was selling his on here with a harness another member made but no dice. Ill juat t tap into the factory harness instead of running more wires.
  25. Jan 22, 2018 at 5:13 AM
    DaBoro54
    DaBoro54 Beach Fisher
    Leveling kit, 285/70R18 EXOs
    darkknight2014 likes this.
  26. Jan 22, 2018 at 5:56 AM
    darkknight2014
    Phil
    New york
    2014 tundra sr5
    Damn that might be them. Good eye.
  27. Jan 22, 2018 at 7:26 AM
    DaBoro54
    If you get them,let me know if they work and I’ll buy a set too
  28. Jan 22, 2018 at 8:26 AM
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    I would love a plug/play fog mod. I want to retain the factory switch and I don't want to cut/splice wires under the dash. No one has made that happen yet?
  29. Jan 22, 2018 at 9:05 AM
    darkknight2014
    Phil
    New york
    2014 tundra sr5
    That harness is whats needed. I just ordered it we have h11 fogs
  30. Jan 22, 2018 at 9:06 AM
    darkknight2014
    Phil
    New york
    2014 tundra sr5
    Just ordered should be here tomorrow
    DaBoro54[QUOTED] likes this.
